Anyone hear anything. Hope he is ok
1968 firebird cameo white on red 400 4 speed 1969 carousel red firebird 455, richmond 5 speed 1964 gto pump gas, 505 IA2 EHeads, EFI, 92 mm turbo ice cream getter in process now.... 1970 lemans hardtop, gto clone Atoll Blue 1972 Maverick powered by 2004 gto ls1 and t56 6 speed, 8.8, fox strut front end, wifes car |
from drc - Both cars start their burnouts and then Geise's turbo GTO gets in his own oil and nails the guard rail with the right front fender.
Dave Polichena |
Curts ok, right?
Found out Curt's OK. He'll be back at work tomorrow.. I'll give him a call and try to get details. Hope the GTO wasn't too damaged when he hit the guardrail.
Proud member of the CV-1 "Banned of Brothers"
Glad its not worse and hope Curt is fine. Hope the oil problem was something like an oil line and not a hurt motor.
Very Sorry to hear that BAD NEWS (the crash).
Tom Vaught
Hope the damage is minimal. Main thing is that he is a OK.
That stinks. Hope it's not too bad.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion 2024 Chief of the Pontiacs |
What everyone else already said.
Just talked to Curt. He's just a little stiff from hitting the guard rail. He's not exactly sure what caused the car to pull into the wall. As for the car, Curt said the GTO has a couple bent tubes and some body damage but the drivetrain is OK. If all goes well he'll be racing a Firebird in Super Gas this weekend. I have to give Curt credit for jumping right back on the saddle again so soon. Definitely a hardcore racer.
Way to go Curt!
Glad to hear he is ok. Car's can be replaced, people can not.
************************************* 463 SRP .035 Pistons, Eagle rods, N crank, Pump gas, Victor intake, Holley 850BT carb, 6H heads,TH400 w/T-Break, Continental custom 3500 converter, 3.73 gears. TV7101 TURBO! |
Thanks guys -- Got a sore neck and bruised ego -- Best I can fugure was to much wheel speed on the burn out - when I lifted the car was crooked and the the rear tires hooked and pushed the car sideways into to the wall - happened so fast I couldnt get hold of it in time - drive train and suspension all ok - some frame rails and a fuel cell have seen beter days along with some fiberglass damage -- one more leason learned -- I hope
Glad you are OK Curt!
X3! Sorry to hear about the mishap... I can certainly relate to tire hook when pointed in less than desireable directions! Hope you can get that animal back on the track no worse for wear.
The secret to happiness is not getting what you want but rather, wanting what you have. |
X4 Curt.
68 Firebird Are you running with the wind or breaking it? |
I'm sorry to hear that!
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines! 2006 silvy Z71 4X4,383 LS 600+hp NA Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-} |
Glad to hear you are fine.
Glad you are OK. Hope your car is back on the track soon.
Hundreds of Pontiacs in Az "Real Pontiacs only..no corporate nonsense!" Facebook- Pontiac Heaven Hosting- 23rd annual Pontiac Heaven weekend- Phoenix pending due to covid Pontiac Heaven Museum in process Phil 2:11 |
Curt, read about it on the bullet. Glad you OK. Don't feel bad. I have seen that happen a few times to guys that had a lot of years behind he wheel of fast cars.... Up on the tire and all of a sudden WTF!! I hope it is easy repair ..... Jim
D-ports ROCK !! |
