Old 08-25-2011, 01:18 AM
Tom,
I've always wondered why I hadn't seen someone use 2300 series Holleys on a Tri-Power manifold. Now, I have!
Dr. Thomas Sowell
Old 08-25-2011, 08:29 PM
Tom Vaught's Avatar
Boost Engineer
Originally Posted by hurryinhoosier62 View Post
Tom,
A Good friend of mine, Bill Klausing, one time installed 3 of the Holley #6425, 650 CFM 2 bbl carbs on a 66 Cast Iron Intake. I told him I thought that the 500 cfm carbs might be a better deal for him. The #6425, 650 CFM carbs have special venturis with built in annular discharge passages. CFM is about 437 each so over 1300 REAL cfm on top of the intake.
That being said, the car was a 1963 Catalina Wagon with a built up 455 engine using ported cast iron heads. The car ran 12.06 ET but only ran 106 mph as the body was a "brick" at speed vs 115 mph. The car ran the fastest ET/MPH with the end carbs NOT open all the way at wot.
Tom Vaught
Old 08-26-2011, 07:31 AM
3X24SPD 3X24SPD is offline
I guess I can understand using the Holley's on an aftermarket Six Shooter...
Good info Tom- do you know what that BG intake flows compared to factory iron?
1966 GTO (Red) WARPATH
469CI TriPower 4-Speed
1965 GTO (Black) TRIPOWR
455CI Weiand Dragstar with 6 Strombergs
4-Speed
1965 GTO (Blue) 3X24SPD
464CI TriPower 4-Speed
1963 Tempest (Red) VIOLENT
440CI 2X4 Mag Nash / T400 (for now..)
Old 08-26-2011, 03:13 PM
Tom Vaught's Avatar
Boost Engineer
The BG "Six Shooter" Intake Sucks out of the box. For me personally, the first "Six Shooter" intake I bought did not fit, (:>( as the fasteners did not clear the intake ports properly in some spots. Carbs would not bolt down either.
I talked to BGTECH and he had me sent the intake back and he made it right (NEW 3rd generation intake). No complaints whatever with BGTECH. That being said, the BG intake
communication ports (internally) were way undersized and the ports were somewhat different sized. Probably like some of the latest 66 Rochester TRI-POWER aluminum intakes. The two "1st run" 66 Rochester TRI-POWER intakes I have are very nice.
So as I said I had Dave Wilcox work over the BG Unit. Should work well now and hopefully will flow as well as Slowbird's dad's Ported cast Iron Intake.
Tom Vaught
Old 08-26-2011, 08:11 PM
NBF823's Avatar
NBF823 NBF823 is offline
Can you buy the BG six-shooter intake alone, sans BG carbs and such?
Jon B
Old 08-26-2011, 10:56 PM
Tom Vaught's Avatar
Boost Engineer
No, not normally. I bought the intake at a swap meet from a dissatisfied customer.
But Like I said BGTECH stepped up for his company and made it right.
Tom Vaught
The Bore Sizes for the Throttle Blades are the same for the Large 66 Rochester carbs and the Holley "500 cfm" carbs. I believe that you could machine a 1/2" off the aluminum Rochester Tri-power intake pads and weld on the Offy solid aluminum Holley pads and have a very good intake (with a factory carb height). A Lot of the 66 aluminum Rochester Tr-Power intakes out there if you want to spend some money and a Lot cheaper vs the BG parts.
Old 08-27-2011, 07:51 AM
Thanks Tom.
If anyone here is interested in a complete BG Pontiac Six-Shooter setup, I have a friend who has one locally (used) that wants to get rid of it very reasonably.
I checked it out, but it just doesn't work for me, for reasons previously stated.
PM me if interested.
4-Speed
Old 08-27-2011, 09:31 PM
Default 69 Low Rise
3 Holleys on the 427/435 Corvette (1969)- low rise, with vacuum actuated outboard carbs:
4-Speed
Old 08-27-2011, 09:37 PM
3 OE Holleys on the 1967 427/435 Corvette high rise intake, with the original factory vacuum diaphragms removed on the outboard carbs, and a progressive mechanical linkage installed:
4-Speed
Old 08-27-2011, 11:48 PM
brut4s's Avatar
brut4s brut4s is offline
3x24sp... amy pics of your cars?
