Old 12-03-2012, 02:15 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
This may be the only picture I took.
Old 12-03-2012, 05:25 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
So how do you get the rod to the pump after the pan is installed?
Skip Fix
Old 12-03-2012, 08:07 PM
428RA4's Avatar
428RA4 428RA4 is offline
My guess is to grind off the tab on the shaft so you can slip it in from the top of the block. Be careful not to throw the shaft off when installing the distributor. If you do that you will lose the shaft into the pan and have to pull the motor.
been there done that. no fun...
Old 12-04-2012, 03:49 AM
The shaft is two pieces with a hex slip-joint. One piece stays with the pump. The outer piece is slid in (through an O-ring seal) after the pan is on. It's retained by a bolt through an arm on the outer end (into a tapped hole in the aluminum O-ring block). So adjustments are only in full-turn increments, which is a three PSI change (range is about 60 - 90 PSI). A mini-starter makes it very easy to get at the adjustment.
If you've got LOTS of time someday, I'll try to explain how the center carb's power valve is also now externally adjustable on that engine- with the air cleaners in-place! Not to mention the remote idle-mixture knobs of the center carb...
Old 12-04-2012, 04:11 AM
WDCreech's Avatar
WDCreech WDCreech is offline
Im a dealer for Titan and can get you a little better price than buying direct.have too have it drop shipped or shipping back and forth to Alaska would eat that up.
Marty
Old 12-04-2012, 09:42 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Marty
What oil pan modifications are necessary to run the Titan pro pump?
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 12-05-2012, 12:45 AM
WDCreech's Avatar
Jim
That was my son's post above, but I can tell you that the pan needs more room at the rear. We did it with a BFH and had a hard time with the pan sealing to the rail. I think that you can now get pans specifically made for a Titan pump, so I'd ask Titan if you are thinking about ordering thier pump.
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
[email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
Old 12-05-2012, 12:58 AM
slowbird's Avatar
slowbird slowbird is offline
For the price of a Titan why not run an external belt drive pump? Makes it really easy to prime the engine and gets rid of the cam twisting caused by running the oil pump off the back of the cam.
Old 12-05-2012, 02:56 AM
WDCreech's Avatar
The Titan pro billet pump is a really good oil pump toriington bearings on the inner drive gear. we've been using the same one since the 90' before they even made onefor a pontiac, with no wear. it's really just a ford one with a different adapter.
Yeah, when you stretch the back of the pan with your BFH it pulls the front toward it and you have to double up on timing cover piece.
Marty
Old 09-03-2017, 05:57 PM
Dragncar Dragncar is offline
Has Mark Luhn come out with his geroter Pontiac pump yet. Have to get my ducks in a row for the engine I am building.
