Old 06-04-2012, 09:36 AM
The Boss's Avatar
The Boss The Boss is offline
Beyond that, I am going to drive the snot out of it.... and leave it alone as much as possible.
Just what I wanted to hear!
And go racin' in the street.
Old 06-04-2012, 09:41 AM
Gator67's Avatar
Gator67 Gator67 is offline
Sounds like a great plan!
Old 06-04-2012, 05:30 PM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
Makes more sense to me now. The bigger guy and yourself do not look old enough to have this car stored for a long, long time. It seemed like a car that was stored a long time due to the hooker header stickers and the wheels/tires. When you stated previous owner, I was having trouble figuring out which guy in the photo was old enough to own it for so long. I thought the hippie looking guy might have been the previous owner and maybe you got the photos out of order
Since your main focus is not to restore the car before driving it, then it sounds like a barn find to me. I agree completely with what you are doing to it. I tried that with mine, but we had issues matching the paint with the few spots that needed fixed, so the whole car ended up getting re-painted. I'll bet that paint will look pretty good when buffed out. Nice car regardless.
I too am looking forward to more photos.
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
Old 06-04-2012, 05:37 PM
Unclesamscandy's Avatar
Unclesamscandy Unclesamscandy is offline
Daryl is the skinny guy! He drives across country for the right car!!!
Old 06-05-2012, 10:13 AM
squirejohn's Avatar
squirejohn squirejohn is offline
Thumbs up
Nice to see there are still finds to be had.
I love the pics with the retro (wasnt then) rims and the hooker header emblem on the side.
Glad you saved her and looking forward to progress pics.
squire john
1967 LeMans
1973 GTO
1973 Grand Prix
1973 project X
1991 Sunbird V6 convertible (wifes)
Old 06-05-2012, 11:58 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default Pinstripes!
I hope you try to preserve whats left of the factory dual pinstripes. I have had very good luck protecting them during a buff / wax job by applying a gentle tape over them and coming back later with a "100% wax" gently by hand to bring up a shine. DO NOT use any cleaner type wax as it will remove whats left of those old dry black stripes. COOL 67 HO! Thanks for sharing the find!!!
Old 06-04-2012, 11:37 PM
GTO JOHN's Avatar
GTO JOHN GTO JOHN is offline
Nice find. Looks like a Rat Muscle contender at this year's Muscle Car Classic.
John
Email [email protected]
My Website www.minnesota-muscle.com
Old 06-05-2012, 12:14 AM
SD421's Avatar
SD421 SD421 is offline
Wow, great find indeed.
BTW I hope you also changed the oil before you fired her up. When I bought my Goat back in 1991, the car had been sitting. I drove it home and went out that night messing around in it. The next day, I went around a corner and punched it. Well, the oil pump seized up and snapped the distributor driveshaft.
Needless to say I had to pull the motor and wound up rebuilding it.
If I had just changed the darn oil after I had gotten home things might have cost me less.
Don
1966 GTO
1966 421-10.1-1 comp-Race Tec 23cc Pistons
KRE Tri-Power
KRE 65cc Aluminum Heads
XE274 cam by Comp Cams
DUR 230 Int 236 Exh @.050 - 110 LSA
LIFT .491" Int .491" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 06-05-2012, 12:08 PM
60sstuff's Avatar
Same thing happened to me years ago. It involved a 67 HO 4spd. I found that had been sitting for years. I did all the pre-drive preparations as mentioned but there were small particles of teflon which came on the original timing gears that somehow jammed up the oil pump and twisted and snapped the shaft to the distributor. USE CAUTION on this old beast!
Old 06-05-2012, 11:53 AM
Tygrr67 Tygrr67 is offline
i'm glad you mentioned the oil change.. But yes.. That actually was the first thing I did to the motor. I plan on changing out again after a few more hours on it.
No,the trans am is not for sale. Thank you for the interest though.
Finally, I will be posting pictures of the car as it progresses. I seriously intend on using this as it is. So for now, the hardest decesion I have had to make is getting the right personalized collector plates for it. Right now, the leading contender is "HO67GTO"
Old 06-05-2012, 07:52 PM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
Fantastic! I always appreciate a car that's driven regularly. Mine fit in this category.
As to the personal plate, I totally understand. Like you, I'm thinking of a personal plate for my '71 Vert, when that day comes...
Another option might be to use a 'period correct' plate? I don't know the rules in your state, but here in AZ we can use original 'vintage' plates on our cars. I've sourced correct ones for my fleet, and pleasantly surprising, the color combos work very well with my cars' colors.
ID:	286766   Click image for larger version
Eric Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
Deuteronomy 8:3
Old 06-06-2012, 12:06 AM
Ken N Gilbert's Avatar
Ken N Gilbert Ken N Gilbert is offline
Default Hey Mister Pontiac
I am plating up a 67 vert in Arizona in the next couple of months. I love the look of the plate on your 67. Did you go through DMV for that or just how did you get it?
Old 06-06-2012, 12:28 AM
Gator67's Avatar
I've done this a couple times this past year. I bought a plate at the Gilbert swap meet and another off eBay. To check whether your plate will work (check before you buy it) go to the following Arizona DMV webpage. It's for checking the availability of number/letter combinations for people interested in buying vanity plates, but it works for the purpose of verifying the availability of number/letter combinations for year of manufacture plates as well.*
https://servicearizona.com/webapp/ve...startChoice.do
Click on the top button "Check my personalized plate choice" and then "continue"
Another page will come up with a bunch of plate designs. Ignore all this and go to the bottom of the page and type in the plate number where it says "Enter Plate". Don't try to enter a dash if one is on the plate. So if your plate is GTO-455 just enter GTO455. Hit "search" Another page will come up and tell you if the plate number is available or not available.
From my understanding of the DMV rules, the year of the plate needs to "match" the year that the car was manufactured. So, for example, you can't use a maroon colored plate from the 1980s for a car manufactured in 1961 even though at some point such a plate could have been assigned to the car by the DMV for a different owner. It sounds kind of arbitrary, but rules are rules I guess. Keep in mind that plates for certain years were used for multiple years. For example, plates stamped with "1966" were used from 1966-1968. The plate for my 67 is a 66 plate with a 67 registration sticker. The plate for my 68 is a 66 plate with a 68 registration sticker. I don't know if you actually need the registration sticker with the correct year, but they were readily available so I got them to be safe.
Old 06-06-2012, 12:37 AM
Default Thanks Gator
Thanks for the info. That is a clean look so all I need to do now is find a 66 plate.
Old 06-06-2012, 01:23 AM
Gator67's Avatar
And after you find an "available" plate, you have to take it to the DMV for final approval and registration.
