No, I just didn't 0 deck. Scr is 10.25:1, dcr right around 7.5:1. I'll set timing at 14 and see how it likes it. I'm regretting not having the block decked; probably something I'll do in the next year or two, especially since I plan on throwin on a set of aluminum heads around that time. I'm happy with the 190 running temp in 110 degree weather though.. At least I did something right with the cooling system!
1969 GTO .040 over 400, 68cc #62 heads, stump puller cam TH400, 3.31 posi |
![]() Quote:
![]() Quote:
Yup, and step on the gas and the advance goes away, prevents off the line ping. You can play with the pump shot to make it right. You are also able to close the throttle plates more at idle, giving a better signal & vacuum. With an adjustable can, you can adjust how sensitive to throttle it is, at cruise too. Use the Accel cans, and Crane limiters to adjust total.
http://www.summitracing.com/parts/CRN-99619-1/ .
