Old 09-25-2013, 07:30 PM
arbys's Avatar
arbys arbys is offline
Originally Posted by Old Goat 67 View Post
Doing the same for two years on mine. No bugs also. Could it be that it's really just "Cold Air Intake" and not "Ram Air"? Ha.
You remember what Jim Wangers said about the hood scoop?
Old 09-25-2013, 07:33 PM
Old Goat 67's Avatar
Yeah, but it gives the same feeling I had driving a 57 T Bird back in the day.
Cool man, cool.
Old 09-25-2013, 08:12 PM
67gtospud's Avatar
67gtospud 67gtospud is offline
Hmm, some good ideas here, I feel like it would function more as ram air as long as the pan and seal are in place under the hood.
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/[email protected], .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears
Old 09-25-2013, 09:03 PM
arbys's Avatar
Not according to Jim Wangers. He said it's in the location on the hood and facing the wrong direct.
Old 09-25-2013, 09:20 PM
Doug Doug is offline
From an old post by Pontirag on 06-14-2013, 01:56 PM
".......the repop scoops are not the same as the factory ones? I understand that they are a "propriatary design" that only fit the repro hoods, and that you cannot install factory hood scoops in the repro hoods."
This is some info to check out when you want to get the correct "scoop". (Pun intended)
Old 09-25-2013, 09:24 PM
Keith Seymore's Avatar
Correct. The scoop is down in the "boundary layer" of airflow and is too low for any ram effect. It functions merely as a cold air intake (which is worth about .2 of a sec reduction in ET on our car).
Compare that to the Firebird Formula hood, which would be a much better design.
K
'63 LeMans Convertible
'63 Grand Prix
Old 09-25-2013, 09:26 PM
Cool man, cool.
Funny you should mention the T bird, OG -
My dad mentioned to me that the GTO scoop was originally supposed to be taller, ala '57 T bird, but the metal was being stretched too thin and was tearing.
They kept gradually reducing the height and revising the shape until they could repeatably manufacture a part - and that is what determined the final design.
K
'63 Grand Prix
Old 09-25-2013, 09:51 PM
GT182's Avatar
GT182 GT182 is offline
K
But the Formula hood scoops would look really funny on a 65 to 67 GTO. I'd lean towards the 71/72 GTO's intakes grafted to the 65/66/67 hood up front for real RAM Air. Kinda like what Shelby did going from the 65/66/67 hood to the 68 RAM Air hood scoops up front on the GT 500. That's where it did trick for the full RAM Air effect.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 09-25-2013, 11:27 PM
Satyr1966's Avatar
Satyr1966 Satyr1966 is offline
I agree that the ram air effect is minimal on the '65 through '67 gtos. The real difference is in the air temperature that makes for a denser charge. By and large, under-hood air is quite a bit hotter than outside the hood air. The larger the difference between the two, the greater the difference in performance with the ram air pan. I am proud to run one of the estimated 300 original ram air pans on my '66. I don't know how great of a performance difference it makes, but it is a part of history. It looks cool too! Jerry.
By diligent effort I seem to be prolonging my adolescence to total absurdity. John D. MacDonald
Old 09-25-2013, 11:34 PM
YNOBIL's Avatar
YNOBIL YNOBIL is offline
K
Keith Another great fact from you. I love History.
Bill Nawrot (Wino Bill)
1972 GTO Hdtp One Owner, GTOAA "Concours Best Original" 2007, 2013, and 2019
Auto-Biography http://oneownercollectorcar.com/inde...to-bill-nawrot
HPP Sept. 2014 https://www.hotrod.com/articles/1972...-gee-no-g-t-o/
YouTube MCACN 2014 http://youtu.be/1IPQVPevbxU
1967 GTO Conv
K
I would believe that Keith. Makes one wonder how Ford did it? That metal was probably thicker also. Always thought it was akin to the T Bird scoop. And, the T Bird scoop had a block off plate that one could attach to the rear of it to close it off.
Charles
Old 09-26-2013, 12:28 AM
GTO JOHN's Avatar
GTO JOHN GTO JOHN is offline
Charles
The Ford scoop is smaller in overall area than the GTO scoop despite the height difference so the metal would flow less and not tear when being drawn into the form. I can see the huge GTO scoop being an issue since that is a huge draw (area wise) and if the 1965 hoods were thinner gauge than the 1955 Ford hoods, you could get a problem with metal flow and tearing.
John
Email [email protected]
My Website www.minnesota-muscle.com
Old 09-26-2013, 08:37 PM
geeteeohguy's Avatar
Spud, here's a photo of the functional scoop on my '67. Still looks stock, but from the side, you can see light through it.
Jeff
Old 09-26-2013, 08:40 PM
arbys's Avatar
It looks like the whole piece is painted flat black. Is that right and did you use a cutoff saw and cut the back of the louvers off?
Old 09-26-2013, 09:21 PM
The whole thing is painted a semi gloss black. I used a cut off wheel perpendicular to the back and just ran it along the back area crosswise. No need to cut between the fins. It's thin aluminum and goes away really quickly.
Jeff
The Following User Says Thank You to geeteeohguy For This Useful Post:
Old 09-27-2013, 06:03 AM
67gtospud's Avatar
Thank you, I will have to give this a shot.
Old 09-27-2013, 05:22 PM
Satyr1966's Avatar
I've done this to two scoop inserts myself. I think it's the best looking way to have functional scoops & also helps to keep debris out. If I was going to race the car, I believe I would pull the whole insert out & make a larger opening for the intake air. I've always felt that the small openings with the ribs still in might impede airflow a slight bit.
  #38
Old 09-27-2013, 07:33 PM
jd66 jd66 is offline
reading all the posts I guess Its what a guy wants to do, I had a machinest friend of mine mill mine out and left the ridge around the fins, looks good to me, as for leaving the fins and cutting between them I remember reading along the same lines about satelite dishes that where perforated allum. after the wind blew so hard it didn't make any differance if the holes where there or not, being an X drag racer we all know the best place to get the air is at the base of the windshield. just my opinion. jd grim 66 gto
