Old 01-02-2014, 10:56 PM
165th's Avatar
165th 165th is offline
Originally Posted by Mezzo View Post
Did you use the same OER high solid silver on the axle and brake drums? If so where was it purchased?
Call me crazy, it's ok, I've been dealing with these demons for years, but I've always been of the mindset that if the 'Shades of Gray' vary for the different parts, there is a greater character and depth to the completed unit that makes it interesting to look at when taken in with the rest of the underside. I'm certainly not advocating that these particular shades represent the exact color of a bare steel tube or cast iron part or annealed flat bar spring, but it does in my opinion give the assembly character, while being easy to maintain at this level.
The picture in the previous post of the CM-G rear with the assembled springs did have brighter drums originally but I changed that to more of a cast color later, and is now more like these examples of a GY-G rear end.
With that said:
Primer is Tempo A702 Zinc Phosphate primer. Need lots of light coats. No heavy coats or it will never dry... unless you can fit the part in your wife's oven. Found at your local aviation parts house or online.
To get rid of the surface pitting on the steel tubes, glaze coat and/or Evercoat high build primer, sanded smooth
Steel tubes: Seymour Stainless Steel 16-054
Cast iron pumpkin: Eastwood Spray Gray
Brake backing plates: Eastwood Brake Gray
Brake drums: Bill Hirsch Cast Iron High heat primer.... Cooked in the oven for curing and maximum spousal anxiety.
Leaf Springs: OER High solids silver K89580 from Classic Industries or probably found online too.
Polished off with some custom made decals correct for the application and some Quanta inspection paint replicated paint daubs from known original examples.
I hope some of this information is helpful.
ID:	348264   Click image for larger version
ID:	348265   Click image for larger version
ID:	348266   Click image for larger version
The Following 2 Users Say Thank You to 165th For This Useful Post:
Old 01-02-2014, 11:08 PM
165th's Avatar
Here's the result of a rear end I did a few years ago to give you an idea how it looks installed.
ID:	348269   Click image for larger version
ID:	348270   Click image for larger version
Old 01-03-2014, 04:48 AM
Norwood's Avatar
Norwood Norwood is offline
I'm never looking underneath my car again
Old 01-03-2014, 07:24 AM
Brewster's Avatar
Brewster Brewster is offline
Those inlet exhaust pipes where originally welded to the muffler and what color are those tank straps black or green?
Ha, Looks great Gregg and love those leaf springs!
Old 01-03-2014, 08:17 AM
165th's Avatar
Nice catch! Gardner does what he does, but I didn't know that one or I would have tweaked it before the install. Straps black or green??? It's too hard to tell from exposure in this picture, but I don't think I knew that about the straps at the time so probably going to have to say black. To the best of my knowledge that car has never surfaced here on these boards since the RM Auction several years ago.
Here's a couple of before pictures that shows why I decided to fluff the rear end and improve the exhaust. This area of the car just wasn't done to the level of the rest of the car. You may have missed the 4 black bolts in the floor pan filling/hiding the holes left behind by the Magna Flow exhaust pipe hanger brackets.
Other than this area and a few other minor spots, the car was awesome, so it was definitely worth the effort.
ID:	348291   Click image for larger version
