Old 04-23-2014, 03:17 PM
webfoot's Avatar
webfoot webfoot is offline
Here is a pic of that adapter. I am not 100% sure if this is the correct part because it has "Stewart Warner" stamped into it in cursive letters. However, my car was originally a 3.90 rear and would have used one of these.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 04-23-2014, 03:38 PM
cballweg cballweg is offline
Is this the one that came off your GTO?
1969 Matador Red GTO Judge,1999 Ram Air Trans Am,1998 Daytona Pace Car Grand Prix,1959 Bonneville,2004 GXP Bonneville.
Old 04-23-2014, 04:08 PM
webfoot's Avatar
Yep.
-Jeremy
Old 04-23-2014, 05:16 PM
How much do you want for it?I also need the speedometer gear that goes in tranny for a 3:90 rear gear if you still have it.
Old 04-23-2014, 05:17 PM
This bolted in to your tranny?
Old 04-23-2014, 05:29 PM
webfoot's Avatar
It has the groove in the side for the tab that retains the normal speedo cable, the part I am holding goes on the trans side. The other shaft faces the front of the vehicle. You can have it for $20 shipped, I really have no idea what its worth.
I don't have the gear.
-Jeremy
Old 04-23-2014, 06:01 PM
Do you have a paypal account?If so give me your paypal address so I can pay you.If not how do you want paid and give me info and your address.Does it have a cable that goes into the tranny to turn speedometer gear like the ones I have seen of these do or is it missing?Thanks
Old 04-23-2014, 06:34 PM
webfoot's Avatar
I don't have anything else that is supposed to go with it, sorry. As for how it works, I have no idea as my car was totally disassembled when I got it.
-Jeremy
Old 04-23-2014, 07:03 PM
Ill take it.If you dont want info on here send me a private message so we can determine how you want paid.I still like paypal if you have an account.Its easy and faster but if not youll have to send me your address.thanks
Old 04-23-2014, 07:07 PM
webfoot's Avatar
I did a bit ago via PM.
-Jeremy
Old 04-23-2014, 07:20 PM
Sent address with paypal and PM.Thanks again
Old 04-23-2014, 10:16 PM
Ram4king's Avatar
Ram4king Ram4king is offline
I don't know where all this info comes from but you are way off. As a restorer and collector of 69 gto' s for 30 years I've never seen or heard of a 69 having the Speedo cable on the passenger side. I've had ones with ratios of 308-433 and everyone had it on the drivers side. I've never seen a Speedo adapter on a stick car EVER. Automatics only. You do what u want but the correct trans is the one with the Speedo on the drivers side.
Old 04-23-2014, 11:10 PM
g68mike's Avatar
g68mike g68mike is offline
I agree with Ram4 king. All 68-69 GTO's had the speedo on the drivers side. I think firebirds and chevy might have them on passenger side, but not 100% sure. Definitely GTO on drivers side. You can look in the 69 assembly manual and it clearly shows drivers side speedo's.
Old 04-24-2014, 06:09 AM
Ben M.'s Avatar
Ben M. Ben M. is offline
What about the 3 speed Dearborn? Serious question!
Old 04-24-2014, 12:09 PM
Why would the automatics have the ratio adapter and a 4-speed wouldent?Thanks
Old 04-25-2014, 08:15 AM
poncho447's Avatar
poncho447 poncho447 is offline
I parted out a 68 LeMans with 3 speed Dearborn trans, as I recall the speedo was on the passenger side of the trans but I can't be 100% sure now.
I have one file photo of the drivers side of the transmission, It's not the best picture but I sure don't see a speedo gear mount.
Old 04-25-2014, 08:33 AM
poncho447's Avatar
FWIW
I owned a 69 GTO 4 speed with a/c years ago and it had the speedometer ratio adapter, as I recall it had a 3.23 ratio rear differential.
I suppose it is possible it could have been added at sometime over the years but the car did have it's born with drivetrain, motor, transmission and rear differential.
  #38
Old 04-25-2014, 08:45 AM
Poncho447,was the speedometer mount on drivers side or passenger side?
  #39
Old 04-25-2014, 08:52 AM
poncho447's Avatar
The speedo mount was on the drivers side, I have never seen a GTO 4 speed car with a passenger side speedo mount.
