Old 12-26-2014, 08:48 AM
chrisp chrisp is offline
How about the correct mount location of the capacitor ? I see 3 different locations in the pics. 1 is obvious wrong out of the other 2 which is correct ?
Old 12-26-2014, 01:03 PM
Dick Boneske's Avatar
Originally Posted by remy30006 View Post
on the manifold bolts the throttle bracket and the pcv bracket bolts should be natural? meaning zinc coated?
was the driver side wire loom dipped or have a plastic loom? My car was last week of january and a 4 barrel.
Also was there another pcv bracket further forward and on top that the hose rested in on tempest engines? I have seen them on big car engines.
Thank you everybody!
The PCV bracket for the 4 bbl.-only engines was painted, so it seems the manifold bolt securing it would be painted, also. I've only seen one hose bracket on 4 bbl. engines---mounted just behind the "F" fitting.
Driver's side plug holder was dipped for Tripower engines, but may have been the plastic-type on 4 bbl. engines. The reason for the dipped bracket would likely be for air cleaner clearance on the big car Tripowers.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 12-26-2014, 06:04 PM
bill ryder's Avatar
bill ryder bill ryder is offline
http://https://www.youtube.com/watch?v=-EC2j-rRdWo
Watch this youtube video. Plenty of good info from asurvivor, maybe. "Bill"!
Old 12-26-2014, 09:48 PM
8LUG 8LUG is offline
wont work
Old 12-26-2014, 10:05 PM
bill ryder's Avatar
http://forums.maxperformanceinc.com/...hlight=youtube
Hello good friend!! Don't know why that link did not work. Try this link to a thread and go to post 22. Dick has the link there and it worked for me.
See you next summer!! "Bill"!
Old 12-27-2014, 08:46 AM
http://www.youtube.com/watch?v=-EC2j-rRdWo Merry Christmas to you also Bill
Old 12-27-2014, 09:57 AM
remy30006 remy30006 is offline
Here are some pictures of the other pcv bracket from my engine. The engine seems pretty original. It was located to the front of the carb on the passenger side on the boss located there. Is this thing suppose to be on a 4 barrel gto?
Also I have a broken bolt for the choke tubes are those grade 8 bolts as im going to have drill it to get it out?
Is the curved heater hose inlet on the front the intake available anywhere?
Thank you!
Name:	photo 2 (16).jpg
ID:	385562   Click image for larger version
Name:	photo 1 (14).jpg
