Old 01-18-2015, 07:57 PM
Scott Rex's Avatar
Scott Rex Scott Rex is offline
Ross 4.375"
GRP 6.735"
Old 10-28-2017, 04:43 PM
grandville455's Avatar
grandville455 grandville455 is offline
I'm sitting here thinking bout this new build and lightening it up from what i had, I'm surprised how light some of these are, compared to mine which i thought ran pretty damn good!
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 10-28-2017, 06:04 PM
PAUL K's Avatar
PAUL K PAUL K is offline
You're using a heavy rod and ring pack.
Go fast, see Elvis!
Old 10-28-2017, 06:30 PM
Steve C. Steve C. is offline
Crower Lightweight 4.125 billet crank
Crower Midweight billet 6.8 rods
JE 4.310 pistons
2303.4
1/2 = 1151.7
Old information here:
Old 10-28-2017, 06:51 PM
Tom Vaught's Avatar
Boost Engineer
Originally Posted by john marcella View Post
Do you mean 6.100 rod ?
If he were talking about a Carrillo 366 cid engine rod or 303 cid engine rod they would be 7.080" inches long John M.
He did not say 366 or 303 engine so assume your rod length question is valid (he had a typo error).
Tom V.
Old 10-28-2017, 07:05 PM
slowbird's Avatar
slowbird slowbird is offline
Must be why my car is a turd, got heavy rods in, and a crank that weighs a ton
Old 10-28-2017, 07:07 PM
Yeap, Going to be changing that Paul!
Darby
Old 10-28-2017, 07:33 PM
Yea, turd , right lol
Darby
Old 10-28-2017, 07:36 PM
DOC DOC is offline
Old 10-28-2017, 08:11 PM
Originally Posted by DOC View Post
2278.6.
what's the combo?
Darby
Old 10-28-2017, 08:23 PM
DOC DOC is offline
455 + .030. Eagle rods, Sealed power forged pistons. factory crank. neutral balance
Old 10-28-2017, 08:33 PM
PAUL K's Avatar
Says the fairweather racer.
Go fast, see Elvis!
Old 10-28-2017, 09:27 PM
slowbird's Avatar
My rods weigh around 850g, crank weighs a ton, don't worry to much about weight. Use the K.I.S.S method! Imo there is next to nothing in reducing crank, rod, piston weights as far as performance goes.
Old 10-29-2017, 08:16 AM
Have u tried lighter stuff Brian? To me anything that helps lighten the assembly the easier to turn n less wear n stress?
Darby
Old 10-29-2017, 08:55 AM
PAUL K's Avatar
Generally that's how it starts out, the lighter the better. As you make more power you need heavier parts to stand up to the additional load. Next you have to pay the big bucks for stronger lighter parts, like ones made out of titanium.
Go fast, see Elvis!
Old 10-29-2017, 09:57 AM
slowbird's Avatar
Ive had lighter rods and crank, no performance difference, in another engine we went from alum rods to steel, no performance difference. The lighter rotating assembly seem to rev quicker in neutral but that's it.
Old 10-29-2017, 10:00 AM
PAUL K's Avatar
When you switched to the aluminum rods and saw no difference, were the counterweights turned down or drilled?
Go fast, see Elvis!
  #38
Old 10-29-2017, 10:11 AM
slowbird's Avatar
We've never had counter weights turned.
FWIW Chris U on yellowbullet has a 9000+rpm record setting bbc with 800+g rods
  #39
Old 10-29-2017, 01:02 PM
PAUL K's Avatar
When switching from a steel rod to aluminum rods you want to turn the counterweights down rather than drilling holes when balancing the crankshaft. Any gain you might of seen from the lighter rods may have been absorbed in windage losses due to the holes machined to balance the crank. You'll also benefit from the shorter counterweight.
Go fast, see Elvis!
  #40
Old 10-29-2017, 01:32 PM
slowbird's Avatar
If that balance hole offsets the gains from the alum rods, then the gain was so small it wasnt going to be noticable.
Besides that how does lighter rods increase performance?
