Old 01-22-2015, 05:35 PM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
Ditto on beefy 350 blocks!!
Old 01-22-2015, 05:52 PM
Rear main sizes were 2.623" in 58/59, while the later small journal blocks were 3" main.
It would be like putting a 400" crank in a 455 block.
The mains would need to be spaced different.
Old 01-22-2015, 05:53 PM
tom s tom s is offline
John 57-58,59 first 3 in main.Tom
Old 01-22-2015, 07:48 PM
Tom, you are right.
I brain-farted typing it out.
Old 01-22-2015, 09:03 PM
Tom Vaught's Avatar
Boost Engineer
I will stick with my early 400 Block, splayed caps, E-Heads, EFI, Twin Turbos, in a 64 Chassis car. 4.161" bore, 3.5" stroke Carrillo Rods, Wiseco Pistons, Turbonetics Turbos.
380 cubic inches, 8000 rpm all day long, no ring support on the piston needed, piston does not come out of the block.
Tom V.
Old 01-22-2015, 09:55 PM
v869tr6's Avatar
v869tr6 v869tr6 is offline
Tom V.
"Engineers do stuff for reasons" Did you put together that killer combo to just let it sit? LOL
Old 01-22-2015, 10:08 PM
Tom Vaught's Avatar
Boost Engineer
I have most of the parts for the engine on the shelf. Crank, Rods, Pistons, Block, turbos, heads were done years ago by Wilson Manifolds (Gaby's old job).
But the stuff sits on the shelf until I can get the 64 Hardtop chassis car out of storage.
The engine would bend up my restored 64 GTO convertible so it is not in the scheme of things.
Have thought many times about cutting out the drag crap and installing a new style Morrison (or other "Road Chassis) under the solid 64 body but with the cage etc hidden in the shell. Better suspension, better brakes, better steering, better tires and wheels, similar to a Tom McQueen build deal but smaller tire. Something like this car in the 64-65 forum: http://forums.maxperformanceinc.com/...d.php?t=733455
Tom V.
Engine will be EFI too.
Old 01-23-2015, 12:59 AM
charlie66's Avatar
I have a set of #16 castings. Will this head be capable of making the power(8-900hp) and are they limited with the higher rpm's?
My Half AN Injun.....
Old 01-23-2015, 03:25 AM
blueghoast's Avatar
Originally Posted by charlie66 View Post
What ci motor did that crank come in.
The crank is out of the 57-block. It's a steel crank and in perfect shape.
It's the motor out of my 57 wagon and I'm not going to rebuild it.
I already did one for my 4-door 57. The wagon will get a 455 motor
when I can get to it. Hopefully soon.
GT.
Old 01-23-2015, 09:30 AM
charlie66's Avatar
GT.
What ci was the 57 motor?
Old 01-23-2015, 10:26 AM
Don Keefe's Avatar
Don Keefe Don Keefe is offline
PY VIP
1957 Pontiac V-8s were 347s.
Founding Editor-in-Chief, Poncho Perfection 10/1/15-12/31/24)
Contributing Editor: Collectible Automobile (1999- )
Author:
"Grand Prix: Pontiac's Luxury Performance Car" (4/27/07)
"How to Restore Your Pontiac GTO" (7/15/2012))
"Pontiac Concept and Show Cars, 1939-1980" (3/25/16)
"Pontiac Performance 1960-1974: The Era of the Super Duty, H.O., & Ram Air Drag & Muscle Cars” (10/15/24)
"Leave the gun, take the cannoli."
Old 01-23-2015, 10:31 AM
As Don said.
List of sizes:
Pontiac Engine sizes
Old 01-23-2015, 10:41 AM
charlie66's Avatar
As Don said.
List of sizes:
Thank you..
Old 01-23-2015, 10:43 AM
charlie66's Avatar
What do you guys think about using the #16's for heads ? Can 8-900 hp be obtained ??
Old 01-23-2015, 12:57 PM
charlie66's Avatar
GT.
Your private message box is full....
Old 01-23-2015, 08:43 PM
Tom Vaught's Avatar
Boost Engineer
Marty's cast iron heads were #62s which are not that different from #16s.
He made a lot of power with those heads before he went to the E-Stuff.
He said his 200+ MPH pass was made with the cast iron heads and a lot of boost.
The heads flowed what a thick runner wall head would flow, 240-270 cfm so the heads were not "paper thin" 290 cfm type heads.
Tom V.
Old 01-24-2015, 02:11 AM
charlie66's Avatar
Tom V.
Hi Tom, what was the average that a stock 16 would flow? I'm assuming 240 was ported..
  #38
Old 01-24-2015, 02:38 AM
blueghoast's Avatar
Sent you a PM.
GT.
  #39
Old 01-24-2015, 02:47 AM
charlie66's Avatar
your pm is still full. Whats a good time?
  #40
Old 01-24-2015, 04:02 AM
blueghoast's Avatar
Did you receive my phone number
I sent you a PM. With my phone #
Give me a call tomorrow afternoon.
I'll try to get time to clean out the PM machine. LOL
GT.
