Old 03-22-2015, 10:01 AM
grandville455's Avatar
grandville455 grandville455 is offline
No graph, dyno was at engine guys shop, local.
Brian we started at 30 after 3 pulls , we checked lash, then tried 32, fell off more n dropped a lot after peak, so then we went to 28, and it was better, carrying it out n dropping not as much, 26 was the last pull #10, motor was plenty heat soaked at that time, we kept it at 170 water n 150 or so oil. There's more power in it yet, If we would've cooled it down for a couple hours, I know it would've went 660 easy.
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 03-22-2015, 10:11 AM
slowbird's Avatar
slowbird slowbird is offline
Were jet changes made? With more timing it probably wanted jetting.
I would definitely jet up with it in the car to start with imo.
Old 03-22-2015, 10:26 AM
We were going to, but pulled a plug n it looked good, so that's when we dropped timing n still made pretty much same power, but carried it out better without dropping near as bad. The EGT'S Were pretty much the same with more timing, so that told me it probably wasn't lean, plus the plugs were good.
Darby
Old 03-22-2015, 10:32 AM
shaker455's Avatar
shaker455 shaker455 is offline
The Tq looked a bit lower than what I would expect and I don't know the rest of the specs??... degreed & jetted?... I see degreed to 106
I did a 462 street engine with a much smaller cam & for the most part 90 less hp but about the same peak Tq
Overall I'd say success Mr. Darby!
You should have a fun season.
Carburetor building & modification services
Servicing the Pontiac community over 25 years
Old 03-22-2015, 10:44 AM
Thanks!!
What did u want to know Jeff? The Specs are on first page. Cam was a custom mike Jones can for this combo, degreed in at 106.4. Jetting was 92 square. We didn't even touch the carb, not even a mix screw!
Darby
Old 03-22-2015, 10:46 AM
shaker455's Avatar
Yeah I missed the ICL on your 1st post...
Pistons, etc whole build...if you don't mind?
Is that the same custom Dominator I built you back in 2011?
So you had 1 dyno day?? good that you got it on there in the 1st place.
Old 03-22-2015, 10:51 AM
400, scat 4.25 forged crank, callies rods with L19 bolts, Mahle dished pistons , coated rod ,cam bearings,4.185 bore, standard 1/16/3/16 ring pack.Program main caps, SD Brace, Cam is 188/190 @200..PAC 1289 springs ,2.0 IH, 250 seat/ 640 open, tool steel retainers, titanium locks.
Darby
Old 03-22-2015, 10:55 AM
shaker455's Avatar
Nice build, you have the heads ported to 325 cfm?
Old 03-22-2015, 10:58 AM
stroker461's Avatar
stroker461 stroker461 is offline
Congrats, that's some impressive numbers, I started to go with the d-ports but ended up going with High ports instead so now ya have me curious on what my junks gunna make lol again congrats should be a fun ride for sure......
Old 03-22-2015, 11:00 AM
Heads flowed that on a tight bench, on my friends 600 they flowed 347@800, YOU can do a search of before and after pics, the heads came from someone else n were ****ed up so I sent them out to be fixed.
Darby
Old 03-22-2015, 11:01 AM
Thanks! I'm curious also on yours! u have a lot more flow n comp I believe.
Darby
Old 03-22-2015, 11:05 AM
shaker455's Avatar
Had my share of repaired KRE's too...
Old 03-22-2015, 11:10 AM
stroker461's Avatar
Yea, there 368cfm high ports on 14:1 461 with 277/288@50 .485/.471 lobe lift and 112 lobe sep with harland sharp 1.65 rockers, im still impressed by your set up ive shared it with alot of my buddy's that's on PY, cuz was trying to talk couple of them in to buying a set of Kauffman D-ports, I never intended on going as far as I have but when I have people running that mouth I just kept buying stuff lol like full Calvert suspension and msd power grid system think I went a little over board but its there for the future now LOL
Old 03-22-2015, 04:18 PM
Darby
Old 03-22-2015, 04:47 PM
shaker455's Avatar
Glad you thought of that!
Old 03-22-2015, 08:08 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Congrat on the good numbers!
Skip Fix
Old 03-22-2015, 08:24 PM
BB70's Avatar
BB70 BB70 is offline
Sounds good!
  #38
Old 03-22-2015, 09:48 PM
leeklm's Avatar
leeklm leeklm is offline
cant wait to see it tearing up the rock!
  #39
Old 03-22-2015, 09:58 PM
stroker461's Avatar
That thing sounds wicked, damn quick on throttle response looked as if it was gunna just come off the stand lol
  #40
Old 03-22-2015, 10:10 PM
Chupa's Avatar
Chupa Chupa is offline
Baddass! I look forward to some timeslips!
