Old 04-09-2015, 01:20 PM
gto4evr gto4evr is offline
with that cable disconnected from the shifter, turn the key on (without the engine running) grab the collar on the steering column and try to turn it to the right, clockwise. it should turn and take the tranny out of park. If it doesn't, then get underneath and try the same thing after disconnecting the pin at the other end of the cable where it connects to the transmission. If it turns at that point, then your cable is seized, if it doesn't turn then you're problem is upwards from the linkage to the steering column.
Old 04-09-2015, 01:31 PM
Darth Menace Darth Menace is offline
Great, I will give this a try. I am also hoping that this is making the neutral switch enabled (or not disabling it...however that works)
Would adjusting the cable be something I should try as well?
Old 04-09-2015, 02:03 PM
Once you establish that it's not the cable, then you can work your way backwards up the frame linkage to the column rod up to the column. The neutral safety will only allow the starter to operate in either it's Park or Neutral position which is directly linked to the clock position of the steering column collar position. If your linkage is rusty and binding, it could definitely have been affecting the switch. On my 71, whenever it gets really cold out, the column won't return completely to the park position. It'll turn far enough to allow the key out, but the car won't restart unless I grab the collar and turn it to the left to seat it in "park" so I can start the car up. I never got around to readjusting it and use it as a security device to prevent car theft!
Old 04-09-2015, 07:34 PM
I just tried this with no success. Just to clarify, with the shifter cable undone where I had the arrow, I am to turn that collar thing right behind the steering wheel, and this should make the shifter go from Park, then into reverse, then neutral etc etc...as though a ghost was magically doing it? I just want to be sure I am doing this correctly. If that is the case then it didn't work out. I dont know how much the collar is suppose to usually spin, but when it moved it it only moved about 1/4 inch.
Old 04-09-2015, 09:25 PM
PontGuy's Avatar
PontGuy PontGuy is offline
Yes, that is what was suggested. If it won't turn more than 1/4" then it sounds like either your cable is frozen in the sheath (pretty common if a car has a ground problem), or something is wrong with your backdrive linkage (possible but unlikely), or the input selector on the trans is frozen (never heard of that but anything is possible).
Earlier it was suggested that you crawl under the car and disconnect the end of the shifter cable from the input selector on the transmission. A cotter pin or clip holds it on. Do this and see if it frees up your steering wheel collar. Since you have the other end of the cable disconnected you should also be able to push and pull the cable back and forth in the sheath rather easily.
While you are at it you can also block the wheels or use the emergency brake and move the lever on the input selector (again under the car) to make sure the trans itself will go from gear to gear. Just make sure it is back in park before you start the car again!
Report back and we'll walk you through the next steps.
1969 Lemans vert, matador red, 462 CI, 3.07 12-bolt posi
1974 455 TA, admiralty blue/red interior HPP "cover car" - sold
"The best way to show a car is to drive it"
Old 04-29-2015, 10:21 AM
1969GTO's Avatar
1969GTO 1969GTO is offline
Don't go cheep on the new cable, get the good GM one, if you want to go cheep, I will sell you my off brand cheep......
color me gone
Old 04-29-2015, 12:49 PM
put a 4speed in her, problem solved!
Old 04-29-2015, 01:07 PM
I wish, but that is long into the future if ever
Old 05-20-2015, 09:27 PM
Finally got the shifter cable and installed it; however, I believe this shift cable has to be adjusted. Does anyone have a link on how I go about adjusting the cable?
Old 05-21-2015, 07:02 AM
PontGuy's Avatar
What cable did you get? If you got a GM cable (in a GM package) as suggested, it is not adjustable. But with the correct bracket that mounts to the trans pan it should work properly without any adjustment. The back-drive linkage to the column will probably need some adjustment so that the neutral safety switch and lockout positions are correct. This is done by loosening the setscrew that holds the rod in the trans shift assembly under the car, sliding the rod to the correct position and then re-tightening.
If you got one of the cheap repops then you may have to play around with the bracket at the trans, and even then it may be a challenge to get it into 1st gear. This is a very common problem with them.
Old 05-21-2015, 08:57 AM
If you got the cheap repop, just send it back is my suggestion. If you got the more expensive GM item, it should work with no adjustments.
I've had the same thing happen with my cable. You have to make sure you keep all engine grounds attached or just disconnect the battery if it's going to be sitting for a while. I had no smoke, no melting of the cable....Just wouldn't move one day.
Old 05-21-2015, 04:28 PM
I've read the entire post now & before you do anything else I would add a secondary ground somewhere from the engine to the frame of the car so this doesn't happen again.
Old 05-21-2015, 08:09 PM
On that car, there should be at least two from the factory. One at the front of the passenger side head to the frame right next to it and one on the back of the passenger side head to the firewall.
Old 05-24-2015, 11:56 AM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
Also, don't forget this ground from pass front frame to inner fender
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
Old 05-24-2015, 12:26 PM
All is well with the shifter cable. Thanks again for the help guys.
The ground on the rear of the passenger side head to the firewall was horrendous....the part to the head was missing the o-clip thing at the end so it was just twisted in a loop and halfheartedly bolted to the head. I will have to check all those other grounds, but given the grounds/electric issues I have had to fix, I will assume they aren't proper.
Now that this issue is solved I am getting my mechanic friend to come look at it top to bottom before the out of province inspection. I am about 1.5 months behind my expected schedule but waiting for this shifter cable to come and the house renos seemed to push it back.
Old 05-24-2015, 01:34 PM
Kurt, I just realized my error yesterday and you've already corrected it. There is no ground strap from the front of the head or block to the frame. The one you posted is the one I was thinking of.
Rear of the passenger side head to firewall and one from the inner passenger fender to the frame at the front of the engine.
Old 05-24-2015, 11:23 PM
Mine comes with the ultra-rare version of an invisible ground strap there. This thing must have been special order and worth a fortune
Old 05-25-2015, 12:08 AM
Not unusual Darth. Both of mine were missing. It's the kind of thing that people threw away over the years. I replaced them after I had the same shifter cable problem you did.
Old 05-25-2015, 12:20 AM
PontGuy's Avatar
My car also has a ground strap from one of the heads to the frame because I added it. Never can have too many grounds
Darth we are all looking forward to the party when your car passes inspection!
