Old 10-01-2017, 04:01 PM
Dragncar Dragncar is offline
That thing is moving. Can we get some info on the differences in heads and the build in general. Was the same cam used with both heads ? What was the cfm of the E heads ? 430cfm HP, so they are pretty serious.
Old 10-01-2017, 05:18 PM
grandville455's Avatar
grandville455 grandville455 is offline
John, Where u shifting that beast?
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 10-01-2017, 06:56 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
That's really moving! Good job with the combo
Old 10-02-2017, 12:46 AM
Probird's Avatar
Probird Probird is offline
Congrats John! That thing is flying.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
2024 Chief of the Pontiacs
Old 10-02-2017, 10:55 AM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
good job. congrats!
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 10-02-2017, 06:02 PM
gman005's Avatar
gman005 gman005 is offline
The old motor was a stock block filled to the water holes. The E Heads I bought from Jeff V. back in 2005 and the cam I bought from his engine builder Jerry Loan. The head flowed around 330 cfm. The new motor is a 535 MR1.
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport. RIP
75 Grandville Convertible.
Old 10-02-2017, 06:04 PM
gman005's Avatar
I was shifting at 7000 rpm. Going to try 7200. I was going thru the lights at 8000 rpm. I think I am going to put my 390 gears back in.
71 Lemans Sport.
Old 10-02-2017, 06:06 PM
gman005's Avatar
The can in the new motor is a 850 lift and its a 55mm.
71 Lemans Sport.
Old 10-02-2017, 06:29 PM
slowbird's Avatar
slowbird slowbird is offline
What gear you running now?
Old 10-02-2017, 06:50 PM
gman005's Avatar
71 Lemans Sport.
Old 10-02-2017, 07:30 PM
slowbird's Avatar
430
You might want to look into your converter, seems to be slipping a lot
Old 10-02-2017, 08:56 PM
JSPONT's Avatar
JSPONT JSPONT is offline
Damn that's hauling the mail!!
Old 10-02-2017, 10:50 PM
BADDTA's Avatar
BADDTA BADDTA is offline
Great job John! That's hauling
Brian
Boobs & bacon
Old 10-02-2017, 11:21 PM
gman005's Avatar
I was thinking putting my 390's back in.
71 Lemans Sport.
Old 10-02-2017, 11:22 PM
gman005's Avatar
How do I check how much the convertor is slipping?
71 Lemans Sport.
Old 10-02-2017, 11:40 PM
BADDTA's Avatar
Take your rpm at the stripe and compare it to what the number is when you take mph, rear gear and tire height.
Brian
Boobs & bacon
Old 10-02-2017, 11:50 PM
BADDTA's Avatar
John, how much power did your engine make?
Brian
Boobs & bacon
  #38
Old 10-03-2017, 06:33 AM
gman005's Avatar
We put the motor on the dyno when the heads flowed 400 cfm and it made 872 hp and I think it was 770 ft lbs of tq.
71 Lemans Sport.
  #39
Old 10-03-2017, 06:41 AM
145.31 x 4.30x 336/29.5 = actual rpm(7116)
I didn't know what tire your running i guessed at 29.5 and if right your slipping almost 900 rpms on top, if taller its worse even.
Darby
  #40
Old 10-03-2017, 07:09 AM
BADDTA's Avatar
Going by Darby's numbers, that's 11% slippage.
Brian
Boobs & bacon
