Old 08-22-2018, 11:57 AM
AG's Avatar
AG AG is offline
An average of 0.415 BSFC is incredible. What A/F readings were you getting? I know my car has the best times at 12.8 A/F.
Old 08-22-2018, 12:14 PM
grandville455's Avatar
grandville455 grandville455 is offline
Darby, so how fast will it push the Grandville, instead of the Firebird?...……….LOL
BTW nice numbers!!!
If I still had it, pretty damn fast ,lol
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 08-22-2018, 12:16 PM
They were pretty much where they were with last motor high 15 low 16, Just The BSFC Is even better on this one. He goes by EGT and how the plugs look as well, Those afr numbers aren't accurate, but he knows his dyno and knows that Doms always read high.
Darby
Old 08-22-2018, 12:38 PM
T Syron's Avatar
T Syron T Syron is offline
Nice build!
Old 08-22-2018, 01:21 PM
rad400 rad400 is offline
uh 8s Darby. Nice combo.
Conrad
79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers.
Old 08-22-2018, 03:53 PM
Dragncar Dragncar is offline
Nice numbers Darby. I see the numbers were still climbing . Never tried any pulls past 6400 RPMs ?
Its going to be a blast your first time out at the track.
Old 08-22-2018, 04:08 PM
Thanks Conrad! Troy were gonna pull it higher today , stay tuned!
Darby
Old 08-22-2018, 04:43 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Darby, did you dyno the last motor? What size is the carb?
Old 08-22-2018, 05:09 PM
S/st 54's Avatar
S/st 54 S/st 54 is offline
NICE!
Great build! Should be a lot of fun.
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 1/8 [email protected] 1/4 [email protected] in St.Louis April 2026
Old 08-22-2018, 07:25 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Great power.
What head flow?
Old 08-22-2018, 07:28 PM
ponjohn's Avatar
BTW nice numbers!!!
our ET / MPH computed from your vehicle weight of 4500 pounds and HP of 728 is 10.69 seconds and MPH of 126.42 MPH.
Old 08-22-2018, 07:55 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Pretty baddass "little" motor with d ports.
Old 08-22-2018, 08:20 PM
Kevspontiacs@aol.com's Avatar
[email protected] Kevspontiacs@aol.com is offline
Nice build Darby. Have fun
Old 08-22-2018, 08:34 PM
Darby, at .415 BSFC your engine is 10-15 percent more efficient than an average high performance engine (.38-.39). Well done! Measuring EGT verses A/F ratio is a far more accurate picture of combustion efficiency. Higher EGTs = more complete combustion and more HP. What stroke are you runnIng?
Dr. Thomas Sowell
Old 08-22-2018, 10:09 PM
Yes I did Scott, it made 651@6500, same carb on that motor that’s on here, my 1050 Dom.
Darby
Old 08-22-2018, 10:11 PM
Thanks!! We made some more pulls today, and they were a tad higher on avg at .423 still not bad!! 4.25 stroke.
Darby
Old 08-22-2018, 10:13 PM
Final numbers today! I’m pretty excited about this motor!! Plugs look Awesome for pump gas!!
ID:	491227   Click image for larger version
Darby
  #38
Old 08-22-2018, 10:15 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Good job Darby! Great numbers.
Go fast, see Elvis!
  #39
Old 08-22-2018, 10:17 PM
Scott Roberts Scott Roberts is offline
Very impressive numbers on pump gas and D ports!
  #40
Old 08-22-2018, 10:29 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
Nice job!
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
