Old 12-17-2018, 03:40 AM
lust4speed's Avatar
Originally Posted by 64speed View Post
It’s funny the lengths people go to to get the pickup tube attached when none of this was done at the factory. I have rebuilt a few SBC and have never done anything but drive it in. I guess ymmv
Except they do vibrate out. Like I said I've found three pickups in the bottom of the pan when pulling engines down. The pic posted was right after we dropped the pan and that's where the pickup was at. The friend had a drop in oil pressure on braking and then we figured out why. Only finding three failures leaves a whole bunch of engines that we took apart where the pickup was fine, but it's such a simple preventative measure to avoid a potential problem.
Originally Posted by 69FIREBIRD76MM View Post
Lustforspeed, it's that the milodon pick up? looks like the one in my motor.
It's been awhile, but believe the first pic with the strap is a Canton pickup and the second without it is a Moroso.
Mick Batson
Old 12-17-2018, 01:44 PM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Bottom Pic is the way your safety wire looks.
Top pic is the way my safety wire looks when attached to the pump.
Notice the multiple wire twists spaced closely together.
The top "Connection" would actually be the drilled hole securing the screen to the Pump Boss.
The other two connections (at 3:00 and 6:00) would be to the pump cover bolts.
Tom V.
The picture of the pump is from my engine. It was built by Jim Moran at MBJ Machine. Like I said above, He's retired now. He's forgotten more about Pontiacs than most here know. I like this approach. This is one of those things, do what makes you sleep at night.
Safety wire can be a good thing. I know. I'm a licensed Airframe & Powerplant mechanic.
Old 12-17-2018, 02:47 PM
HWYSTR455's Avatar
My solution? Use an aftermarket pan with a pickup that has a strap.
When you spend 10k on an (non-resto-build or performance) engine, why in the world would you put a stock pan back on? Sure, you can tack a make-shift baffle in there, but why would you? Can't spend $350 or so on a good pan? After you've already spent 10k on the engine?
All but the stock replacement pans from Milodon and Canton all have pickups that secure positively, with a bolt to the plate. Only the Moroso pans don't. So just don't buy the Moroso pans. Done.
Old 12-17-2018, 07:48 PM
JSchmitz's Avatar
Mine is a street/strip car. The factory pan and pickup are just fine. I've never had a problem with lots of muscle cars owned. These were factory installed and run hundreds of thousands of miles with little or no failures. Factory baffled pan and windage tray. I don't think it's taking much of a beating down there. I'll spend my $350 somewhere else.
Old 12-16-2018, 09:04 PM
69FIREBIRD76MM's Avatar
Old 12-17-2018, 09:05 AM
Tom Vaught's Avatar
Boost Engineer
Another thing to consider is that Chevrolet Oil Pumps do not resemble Pontiac Oil Pumps
(except that the both have Gears, a drive shaft to turn the gears and an assembly cover and oil by-pass system).
So using a Chevrolet "Experience" may not be the same as a "Pontiac" "Experience just as Mick B (Lust4Speed) has had.
Tom V.
Old 03-02-2019, 02:13 PM
SRR's Avatar
SRR SRR is offline
I've never had a p/u tube fall out of a Pontiac engine but did have one fall out of a BBC 396 once and it was in a 1968 4 door HT Caprice. I noticed the gage would nose dive to "0" on left turns. Pulled the pan to replace what I thought was a bad oil pump to find the p/u in the pan. One thing I don't do is reuse a p/u screen, I think once it's been used it no longer has any "bite".
― Calvin Coolidge
Old 03-02-2019, 02:41 PM
Pontiac Performance Author
JS: That's the way I do it. A stock pickup won't twist if you put it in the notch on the pump body. Also, no possible distortion when using safety wire.
Old 03-02-2019, 03:07 PM
JSchmitz's Avatar
Ken, I consider that a compliment!
Old 03-02-2019, 03:33 PM
tom s tom s is offline
I have had one come off in all my years.That will be the last one.Tom
Old 03-02-2019, 04:06 PM
Old Goat Racer's Avatar
Milodon pickup sideways pic. My cell phone does it.
Everybody knows somthin.
Nobody knows everything !
Old 03-02-2019, 05:14 PM
NeighborsComplaint's Avatar
Milodon pan with bolt on Milodon pickup in mine. Low profile pan with side kickouts for add'l volume.
Triple Black 1971 GTO
Old 03-02-2019, 05:24 PM
JSchmitz's Avatar
That's beefy for sure. The small pickup with large holes makes me a little nervous. I prefer the larger stock style pickup with a finer screen . Plus it came with the pump. Add $.02 worth of wire and your in business cheap.
Old 03-03-2019, 04:50 AM
Dragncar Dragncar is offline
I have a oil pump that the pickup was brazed on by my father in 1982. Used it for years, still fine.
I am doing some oil pump modifications right now. Will do a thread on it.
But anyway I had my pump body at work and the machinist was enlarging the tube inlet on the pump from stock (.748) up to .810. I will modify a Ford pickup with a cone shaped end (proper)
There is a issue with the Canton pickups. The I.D is barely 1/2" and the pickup itself is a rectangle (not good) Canton pickups have shown to have issues stabbing the throttle from say 3000 all the way to 6500 RPM with a momentary drop in oil pressure. It catches up but has shown itself on Luhn's oil system dyno and in their cars. The issue is not really there with stock pickups and pans, screen itself is bigger but the 1/2" tube is still barely adequate.
Luhn used to do the .810 tube like I am doing but now go all the way to a full 1.00" O.D. tube. It requires the boss to be milled off and a bolt on bottom plate and boss.
But back to attaching the pickup tube to the pump. The machinist asked me how I was going to attach it. I told him weld it. I have no problem brazing it or simply welding it. I am a welder and have access to all the specialty dissimilar metal rods and all that. But I know whenever you weld cast iron there is risk of it cracking. You can lessen the risk but it is still there.
The machinist told me to silver solder it. It makes the most sense. It is easy and very strong. We use to to "fabricate" hydraulic fittings in a emergency. It holds up to 1800P.S.I. of hyd pressure. Myself I have used it to install custom drain plugs on my GTOs gas tank and transmission pan by simply silver soldering a 1/2" fine grade 8 nut and use a short bolt and copper gasket. Had them on for 20 years.
Its high temp silver solder, not the stuff you use to sweat copper tubes together for your house,s plumbing. But the same process and just as easy, just need a oxy/acy torch vs propane for heat.
In sawmills we use it to hold the carbide/stellite teeth on giant saws.
The Canton strap you bolt to the bottom of your pump plate is a good idea. Solves the issue but the as I wrote the pickup tube size itself and the shape of the pickup are problems, bend is kinda sharp too. And if you want to use a weld on strap you will have to use the thin stamped steel plate. It has the 5/16 bolts so you can use them. But if you want to run the thick cast iron plate, better than the steel one because it is thicker, iron wears better than steel and it is porous you have to use the Phillips head screws that are countersunk. So you have to weld, braze, screw, wire or silver solder.
Their pumps are trick for a Mellings. Have the full 1.00 I.D tube, 15/16 I.D. and a 1/4" aluminum bronze bottom plate, something like that.
My pump will be one click down for from that but still won't have any pressure hiccups stabbing the throttle.
You might think only going up .062 on the tube I.D. is not that big a deal, but it is. Anyone who knows about the increase in flow with dia. increase knows what I am talking about. Its significant.
