Old 05-14-2019, 07:02 PM
RedDirtRoad RedDirtRoad is offline
Default Rear Axle
Thanks to all the replies that helped me with my rear axle question.
The rear was all rebuilt and is from a 1968 GTO 4 pinion Posi with 3:55 gear ratio,
I sandblasted the axle. Drained and refilled with new gear oil and additive.
Replaced the dented rear cover with new, new brake lines, Brakes and inspection marks and decals
ID:	512251   Click image for larger version
ID:	512252   Click image for larger version
ID:	512253   Click image for larger version
Old 05-15-2019, 02:23 AM
That's nice work... I'm switching rears at this time myself. Wondering where you sourced your brake lines?
Old 05-15-2019, 05:07 AM
roy381 roy381 is offline
Default project
Best luck! with the project. I have the same car and specs just finishing up a 4 year + journey.
pics to come having trouble uploading
Old 05-17-2019, 07:44 PM
I bought the brake lines from Inline Tube
Old 05-18-2019, 08:57 AM
here's a few pics
ID:	512456   Click image for larger version
ID:	512457   Click image for larger version
Old 05-18-2019, 09:09 AM
JUDGE3 JUDGE3 is offline
Originally Posted by roy381 View Post
here's a few pics
wow, love that car. my first car was a 67 GTO exact same color and white interior.
that was back in 1977 I was 16 yrs old paid $700 for it and it was pretty nice.
Old 05-18-2019, 03:34 PM
Love the stance and the wheel choice. Nice car!
Old 05-29-2019, 11:01 AM
Default Making some small progress
Sandblasted the wheels
Applied self etch, Painted back of wheels in gray enamel, taped and sprayed with Argent silver then charcoal.
New caps and lugs
I know why I like Rally I's more the Rally II's...HaHa!! so much taping and masking off on a Rally II
ID:	513163   Click image for larger version
ID:	513164   Click image for larger version
ID:	513165   Click image for larger version
ID:	513166   Click image for larger version
Old 10-06-2019, 12:50 PM
My 67 is in the body and metal phase right now
Progress photos coming as soon as there is
Substantial work completed
Old 10-06-2019, 03:23 PM
Mike Davis's Avatar
Nice work, Can't wait to see the progress.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 10-08-2019, 05:33 PM
Default Getting uglier before it gets better
The metal work is being done by JMCR. The shop knows Pontiacs and they have a few gold and silver awards from POIC.
The first thing that was done was fitting the doors using new door hinges before cutting out the quarters and so there is a benchmark knowing the doors now fit perfectly.
ID:	521775   Click image for larger version
ID:	521776   Click image for larger version
ID:	521777   Click image for larger version
Old 10-08-2019, 05:39 PM
Here is the rear sheet metal removed
I have full rear quarters, inner and outer wheel houses, full 1 piece trunk floor, 2 trunk extensions, and an NOS rear tail light panel.
Still a lot more tear down to go. Hopefully new sheet metal will be fitted next week
ID:	521779   Click image for larger version
ID:	521780   Click image for larger version
ID:	521781   Click image for larger version
ID:	521782   Click image for larger version
Old 10-08-2019, 09:18 PM
ZeGermanHam's Avatar
Nice to see some progress! Also, that last photo is is rather spooky with all the sheet metal gone. Not for the faint of heart.
1998 BMW 328is (track rat)
Old 10-08-2019, 10:23 PM
400 4spd.'s Avatar
Thumbs up
Dead on plan. Gotta have the doors right before doing the back half. Please post more pictures as it goes. Considering how the car appears to be currently supported forward of the rear axle, I expect they will also jack up further back on the frame once the trunk pan is ready to weld to the inner wheel housings and the drop offs to the lower quarters. Doing so brings the rear body panel and trunk floor upward into alignment with the quarter panels.
Old 11-02-2019, 12:35 PM
Its been a few weeks and had some more unforeseen rust issues with the drivers side inner and outer rockers. I had to replace them before moving forward
ID:	523485   Click image for larger version
ID:	523486   Click image for larger version
ID:	523487   Click image for larger version
ID:	523488   Click image for larger version
Old 11-09-2019, 03:38 PM
Moving along now.
Decided to replace the package shelf by the real window since it was previously hacked up.
Replaced the filler deck between window and deck lid, full quarters, trunk extensions, full 1 piece trunk too
Everything is fitting pretty good and getting ready for final welding
ID:	524059   Click image for larger version
ID:	524061   Click image for larger version
ID:	524062   Click image for larger version
ID:	524063   Click image for larger version
Old 11-09-2019, 04:30 PM
Looks great. Where did you source the package tray from? I'll have to replace it in my '66, too. I know Ames makes them, but I'm always curious to know what people use.
  #38
Old 11-09-2019, 05:17 PM
I bought mine from Summit because I needed it in a pinch and was able to get it the next day
It's made by AMD and for a Chevelle.
They don't make the full panel for GTO
I was lucky and didn't need the panel but if you do then you have to piece it together because a Chevelle panel is shorter from package tray to trunk
  #39
Old 11-09-2019, 07:49 PM
Actually, if you look in the latest Ames catalogue, they do sell the full panel now. It's a new addition.
  #40
Old 11-09-2019, 10:33 PM
You will find that panel is a Chevelle panel
There is a note under the part starting it needs to be modified to fit
There is a thread on here where to cut and extend if you need the panel replaced
