Old 06-24-2019, 07:39 AM
455TA's Avatar
455TA 455TA is offline
T2 might like a open spacer with the 4 hole Wilson on top of it. If you have the room. I have had good luck with doing that.
A Tomahawk intake works real well for what you are doing too. Fits perfect for shaker hoods.
Did you ever build that engine you were planing on ?
I have both spacers at the house and I should be able to stack them since I don't run with my shaker on anyways. I've used the tomahawk before - I also have a ported Northwind intake at the house but so far my Performer RPM has been 4 tenths faster.... It wasn't apples to apples though because I did add 1.65's after I took the NW intake off.
I never built another engine - life got in the way of that plan but I will eventually!
1980 Trans Am - Street/Strip 462
Best: 7.08@95 with 1.49 60' in the 1/8th. 11.17@119.8 in the 1/4. N/A, 3700 lbs, 3.42's, Pump Gas.
Admin of Pure Pontiac Powered Outlaws on Facebook.
Old 06-24-2019, 07:42 AM
455TA's Avatar
Originally Posted by pastry_chef View Post
Darn good for 9.57 compression. What size header? dual 3 inch pipes?
Ported T2 with spacer would be a great match.
Doug's 1.875 inch Primaries, 3.5 inch collector, 3 inch x pipe with Pypes Race Pro mufflers.
I'm hoping the Torker II doesn't kill my 60 foot.
Old 06-24-2019, 07:43 AM
455TA's Avatar
Originally Posted by scott70 View Post
You gained 25 mph from the 1/8th to the 1/4 which is a good gain for the 2nd half of the track.
It felt like it was really putting the steam on, on the top side.
Old 06-24-2019, 07:46 AM
455TA's Avatar
Here is a video from that night!
This is against a foxbody that had a 302 with a 150 shot.
https://youtu.be/DF7su4vuJ6o
This is the fastest pass - https://youtu.be/A5bJRoXHxyc
Old 06-24-2019, 08:01 AM
chuckies76ta's Avatar
Very Impressive. I've gone from 3.42 to 3.73's rear gear and it never picked up. The 3.42 gear is hard to beat. I've also tried a RPM from the torker 2 with a 1" open spacer and saw no change. I settled on the torker 2 with the 1" open spacer.
I need to try a new convertor. Best we have had a sea level was 10.88 at 122 mph with 3.42 gear.
Old 06-24-2019, 01:29 PM
ta man ta man is offline
Awesome results, it will be interesting to see how your car reacts to the Torker 2, I think you have enough gear and convertor it will like it. As you know with mine..the Torker 2 was quicker in the 60 ft than the rpm with a 3200 convertor but it needs the spacers to really work. Its nice you have both to try and to try both together..I'm going to try that this year as well..just need longer carb studs. Good luck!
Old 06-24-2019, 01:48 PM
Dragncar Dragncar is offline
4 tenths faster, thats quite a bit. The Northwind might be a bit big for what you are doing.
I will be running one on the High Port engine I offered to you. Picked it up here and it was CNC ported by Dave at SD for their 350cfm E heads. Since he has my High Ports he will match them to the intake I have.
Life does get in the way of our cars. They are a luxury, life is not.
Old 06-24-2019, 08:36 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Originally Posted by Scott Roberts View Post
Obviously, they had no idea he was in the Ehead Mafia....
E-heads should be exempt from the roll bar rule...for obvious reasons.
Go fast, see Elvis!
Old 06-26-2019, 10:45 AM
Scott65's Avatar
Scott65 Scott65 is offline
I sure wish that were true!
Old 06-26-2019, 08:32 PM
ponjohn's Avatar
ponjohn ponjohn is offline
What size tire?
Old 08-24-2019, 07:57 AM
Originally Posted by ponjohn View Post
What size tire?
Hi John: The rear tires are M/T 28x9x15.
I'm now wondering if a taller tire might help.
I also need a better convertor for the car.
Sorry for taking so long to reply. hadn't noticed..
Old 08-24-2019, 09:53 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Hoosier "short" (29.5) 30x9x15 radials will fit and not rub body panels on the big end if you want a taller tire to try.
Skip Fix
Old 08-24-2019, 07:22 PM
Thank you Skip
Old 08-27-2019, 08:27 PM
shoebox1.1 shoebox1.1 is offline
Very nice! Well done
GOD does business with people that mean business!
Old 08-28-2019, 10:30 AM
Jim Moshier's Avatar
Jim Moshier Jim Moshier is offline
Nice work. ....Nice car too.
Jim Moshier
1971 Grand Prix 462ci SD Performance 6x heads
1962 Catalina 389
1968 Firebird 400-455 I haven't decided
"If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan
Old 08-28-2019, 10:44 AM
455TA's Avatar
I appreciate it!
Currently adding header crankcase evac system to the car. Have always fought small oil leaks and excess crankcase pressure with this engine so going to experiment with the evac kit and see how it does.
Torker II / Spacer going on before next outing.
Plans are to swap my stock leaf springs with the calvert mono leafs soon, as well.
Really want to see that 10 second pass!
