When people talk about a good tune which my car needs, how much horsepower can be gained by a good tune?
Thanks |
Mild cam, mild compression, small valves,.... based upon other Pontiacs I've dyno tested, you may have another 15 or so HP. Nearly every stock headed Pontiac I've seen on a chassis dyno has put less than 300hp to the wheels. What is your torque, though? People focusing on HP with Pontiacs running unported heads, they are studying the wrong end of the dog.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
If your air to fuel ratio is good through out the motors rev range which it seems to be from your posting of a average 12.8 ratio then the only thing left in terms of getting your motors needs peaked out is to make some dyno pulls / run's while putting in timing changes and to try out different octane fuels.
One thing to watch out for if you go playing with different octane fuels is that the air to fuel ratio can need to be changed from what it is now . With your motors current compression ratio I can't see why anything more then 87 octane is needed to keep the motor alive , and don't forget that running a octane level higher then the motor needs only cuts into the power that a motor makes as the RPM goes up! For a street motor I am not sure if this is a can of worms you want to open because at most your looking at a gain of about 8 hp, and your looking for a missing 30 hp or more, so stick with just trying out some different total timing changes.
Not a bad number for a conservative build.
I'm sure some in depth tuning will make it pretty snappy.
Carburetor building & modification services Servicing the Pontiac community over 25 years |
What RPM did you get the 217? and what did the curve look like coming up to that point?
Clay |
Thanks for the question Greg |
Oh, what do have for exhaust?
If you have decent headers and a good system behind them, then you may see 240's. But if you have log manifolds still, or a restrictive system, then you are pretty much maxed out.
Confirm your torque converter slippage, that could be a big culprit here. Autos eat up more HP in general let alone the converter slippage so I thought...
360hp engine then 280whp with everything near ideal. 12.8 AF seems rich but I'm not sure what the whole pull looks like. A good use of the dyno is to tune on it too, doesn't sound like that happened. Missed your chance to try some fuel, timing and cam tweaks.
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct @ 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline |
| The Following User Says Thank You to GOAT8U2 For This Useful Post: | ||
Still sounds a bit weak to me also. I ran my 30 over 400 with badger cast Pistons, 16 heads and a 226/226 110 cam thru a 4sp at 5000ft elevation and it spun up 297hp/360tq some years back on a portable dynojet machine. I had 195-205 compression and eventually wasted the rod bearings and broke ring lands out of two pistons but it ran pretty good till I pulled it down.
Robert 69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always ) http://youtu.be/eaWBd3M9MN4 |
The answer is right here in the original post... 455 heads on a 400. Low compression no flow... Try some 12 heads or 48...even 62's would be better.
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
yep!! I'd start over with the motor or lower your expectations.
************************************* 1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude |
Clay - Yeah, I've seen the same car dyno on 2 or 3 diff dynos, and the numbers were all over the place. That, and trans/converter also make a diff. You get a sloppy converter that slips 10%, on a 400 flywheel hp build, it makes a fairly large diff. You use a performance built TH400 with high line psi etc on a 350ftlbs engine, you're throwing power away due to parasitic losses. .
The casting # 15 heads with there stock 1.96" Intake valve peak in Intake flow at 185 cfm, the Exh side even though it only has a 1.66" Exh valve flows 155 to 158 cfm.
The overall flow ratio is in the low 82 to 84 percent range which can mean that even if your pumping out the Exh thru stock log Manifolds you do not need a duel pattern Cam like your running. At the Intake valve lift of the Crower Cam your getting about 175 cfm, this amount of flow will be enough to make a very optimistic 358 hp at the flywheel.
And how do I get anywhere close to that 358 hp? Thanks |
If it runs good all around, and you want more, just spray it. A 125hp fixed kit is not that expensive, and usually typical ring gaps will tolerate a 125 shot.
Still missing info, like is the intake ported/port matched? Any work on the heads? Converter/trans/rear gear? Type of exhaust? A 72cc head swap would be a good choice, and swap the intake. 735 carb should be fine on that. If you're considering a cam swap, I don't think you will see any noticeable diff with a 2801, 2802 would be better, but then you're talking about making other changes to take advantage of it. .
Spray is streetable, as is the 2802. The 373s, not so much in many's opinion.
72cc heads, Perf RPM (if you can fit it) port matched, and a 2802 would be a considerable bump. Totally streetable. You could even spray that. .
I have the 72cc heads on my 400 with a cam not much different than the 2802, very streetable, easy cruiser. I made 276 to the wheels with a dyno jet, I had a rusty flowmaster exhaust on it and a flex fan. I changed to a straight through magnaflow and that made a big difference on the mid to top end power. I think with a fan change I could be approaching 300. I would swap out the heads to 72cc and get a little bigger cam, then you will have a snappy engine.
Greg,
Check this thread out. First page has "engine dyno" numbers. And the owner posted professionally tuned "chassis dyno" numbers today. Nearly 150 HP difference. https://forums.maxperformanceinc.com...=808474&page=5 Your engine could have A LOT more than you think. Clay
All the federales say,they could've had him any day They only let him slip away, out of kindness...I suppose Poncho & Lefty |
