Will try and borrow a gauge. It's possible I'm just not remembering things. It's happen before...
- Mike '69 Firebird 400 - Goldenrod Yellow, 455 +.060, '6s-7' heads, Comp Cam 276AH-10 (51-309-4), TH400, Ford 9-inch w/3.08, 800cfm Q-jet, Stock Intake, Hooker Headers, Flowmasters '68 Coronet 500 Convertible - Medium Gold Metallic, stock 318 +100,000 miles |
But the Race Frams are a different deal just like the race Champion plugs are a different deal too. Stay away from the cheap garden variety 2 piece Champion plugs too. Had 2 of them fall in half, one electrode might have went through the engine. It was gone. |
even in the 60's & low 70's my oil gauge on my 60psi pump will read close to 80 for awhile after first start up & idle psi will be 40+ untill 15-20 minutes of driving to fully warm up the oil. just something to consider. he changed to a wix. |
I bought a cheap oil pressure gauge and it showed the same pressure.
Now what?
warm it up fully & check the readings again. it takes quite a bit longer to get the oil hot than when the temp gauge reaches operating temp. next step i would do before pulling parts is to change the oil to something a little thinner & see if it changes the psi back to what you consider normal.
The Summit Racing mechanical gauge is $22 new, is a full-sweep face, and closely resembles the AutoMeter 'style'.
https://www.summitracing.com/parts/sum-g2934/overview/ Skip a beer & cheeseburger at the pub one day and order. If nothing else, you could use it as a reference, and keep it in a box for future use. .
Get a Wix or Napa Gold filter. https://www.youtube.com/watch?v=iTNJLEV8CG8
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, 11.61@116.07 in the quarter...still tuning. |
he posted that he changed to a wix & it does the same thing... |
Driving home last month the oil pressure failed to increase with revs,occasionally it would jump up and stay ok until I idled again,then it would stay low. I was having a nervous fit with only 500 miles on new rebuild. I am running Rotella 15-40 ( the old stuff with zinc) . I got home and took off the filter,K&N,cut it open,clean. Called Ames for a new sender, fitted it,problem solved.
1970 T/A RA3 #'s match. |
kind of off topic, but rotella oil has had lowered zinc levels since 2007, anything sold today is NOT what the "old" stuff used to be. however, all oils still have zinc (zddp) in them, just lowered amounts compared to what they were before the catalytic converter regulations.
Steve25: X2.
No filter cutting tool? That's what a hacksaw is for.
GOOD IDEAS ARE OFTEN FOUND ABANDONED IN THE DUST OF PROCRASTINATION |
I bet this is it.
http://www.machdevelopment.com/album...775/527566.htm |
I missed you tried another gauge, my bad.
I've used a utility razor/knife to cut filters open, just wear a glove. But a cutter is a tool you will find you use more often than you think, once you buy one. I use it for just about every oil change, even on OE newer cars. Back when I ran OE cranks and rods, I ran tighter clearances, in the 18-22 range, and my hot idle was about 40, 60 at cruise/WOT. I ran 10-30 tho. Any idea what your clearances are, mains & rods? What crank and rods do you have? How many miles on the engine, total? I dunno, not sure I would worry about too high a psi, unless it was very high. What steve25 mentioned is totally plausible. Check ball could have been hung from day 1. Build info and miles may help determine that better. .
I had a similar problem a couple years ago...turned out it was the voltage regulator.
#38
Mechanical gauge only.
#39
I miss my '67 Coronet 440...
#40
