Old 05-24-2020, 09:59 AM
Cliff R's Avatar
Cliff R Cliff R is offline
The only manual choke Q-jets I'm aware of were used on some Holden V-8's up thru the mid 1970's......
The Following 2 Users Say Thank You to Cliff R For This Useful Post:
Old 01-04-2026, 02:55 AM
Shiney005 Shiney005 is offline
The GMH built Holden Monaro's that were factory fitted with Chev's between 1968 and 1975 used the 4MV (Divorced choke) while all Holden V8's (308 CI) used the 4MC. All Quaddies fitted to Holden's had the number 8 for the sixth digit of the part number.
The 1974 L34 Torana was fitted with a manual choke from factory. This was a limited run of 263 cars to homologate the model for racing. I don't know if the carbys arrived in Australia already modified by GM or if the work was done here by Holden.
Name:	Quaddie manual.jpg
Name:	1 L34 Torana small.jpg
The Following 2 Users Say Thank You to Shiney005 For This Useful Post:
Old 01-04-2026, 09:54 AM
Half-Inch Stud's Avatar
Thought i'd be ahead of thetech, and removed the Q-JET Choke with big cammed 472s. Worked fine until i went low compression. No cold starting so went with the 1050 for good cold-start.
Then realized cold-start is fine with the Choked Q-JET.
Old 01-04-2026, 12:26 PM
zippy's Avatar
zippy zippy is offline
I have a manual conversion on my Q-jet and I love it with my 455. Here in Canada, the temps vary so much that one is constantly adjusting the electric choke. I pump pedal twice, pull choke on, Fire her up and feather choke down to mid idle after bit, depending on the present outside temps. Allows me to keep RPM up, or drop to the choppy idle sooner.
And it's not that I 'can't" set elec choke up. Its that I Prefer the manual choke in my TA. Also kind of a theft deterrent. Aint no one getting her started when she cold, without knowing where the choke cable is and how to use it.
Dan Pesonen
"If it ain't broke, modify somethin till it is"
Old 01-04-2026, 12:48 PM
mgarblik mgarblik is offline
Default !!
Attachment 663100
Attachment 663101
Attachment 663102
Attachment 663103
Boy, that's another one of those never say never deals! Learn something new every day.
Old 01-04-2026, 04:59 PM
Does that L34 have dual ignition coils? Looks like distributor cap has two coil terminals.
Old 01-05-2026, 02:32 PM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
Talking
Originally Posted by Schurkey View Post
The bigger question is why a person would WANT a manual choke. If the individual parts work properly and are adjusted properly, an automatic choke works well, and seamlessly.
Some people block off their crossovers to keep the manifold cooler. Cooler manifold makes more power. With blocked crossovers the thermal spring type
choke wont work at all. Im glad I live in Phoenix az. I block the crossovers and dont need no stinking choke.
Old 01-06-2026, 02:43 PM
unruhjonny's Avatar
Originally Posted by zippy View Post
I have a manual conversion on my Q-jet and I love it with my 455. Here in Canada, the temps vary so much that one is constantly adjusting the electric choke. ...
When properly set up, you should not need to re-adjust, unless your engine is barely streetable.
Every Quadrajet I have set up with correct ect parts has worked flawlessly year round.
(Also notice that my avatar is my car post-paint, in the snow)
Name:	1998 or 1999 12 27 small.jpg
1970 Formula 400
The Following User Says Thank You to unruhjonny For This Useful Post:
Old 01-06-2026, 09:28 PM
Sirrotica's Avatar
Sirrotica Sirrotica is online now
I have to agree with Jonny. There is absolutely no need for a Q Jet with a manual choke IMO. Likely why GM never offered any such option.
After reading Doug Roe's book on modifying Rochester carbs, attending a GM technical school on Q Jets, plus running them on my race cars, as well as street cars, they're the closest thing to driving a computer controlled fuel injected car when adjusted properly, no matter what the ambient air temp is.
Every circle track car I've been involved with the exception of one car, has had Rochester carbs on them. They need little to no adjustments on them once the carb is set up properly. Yes I've tried holley carbs, but have never had any measurable increase in performance over the Rochesters, and a lot more maintenance to keep them in top form than a Rochester based carb.
There is also a lot less possibility for them to leak fuel onto the engine as there are no gaskets keeping fuel in the bowls such as holleys have, lots less possible leak points, and fire potential.
My , and experiences, YMMV.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
The Following 3 Users Say Thank You to Sirrotica For This Useful Post:
