Old 02-08-2021, 06:05 PM
Scott Thelander's Avatar
got it
Old 02-09-2021, 01:53 AM
shipped
be there b4 the weekend
Old 02-10-2021, 03:35 AM
thank you for the donation to my coffee addiction
Old 02-10-2021, 08:05 PM
Red face
Originally Posted by Scott Thelander View Post
yes its has tinted glass .....
but
you would have a very big leak in your car when it rains ...
the convert is about 4" short on the rear edge for your hardtop ...
sorry
Scott
passenger side glass's have a couple scratches that are tough to see
HAHAHA...........Very big leaks.on.both sides
Old 02-10-2021, 09:27 PM
pontiacman63383 pontiacman63383 is offline
Showed up today and looks great! Enjoy your coffee. Thanks again!
Old 02-14-2021, 05:39 PM
AZgoatguy AZgoatguy is offline
Some years ago I did this very same thing... I wanted to have factory GM AC in my non-AC '69 GTO. With some patience, some welding, and heating and dolly/hammering work, I reworked my firewall to appear exactly as that of an original AC car, and needing only the slightest amount of filler to smooth it. The key to my effort was the template... I used an original passenger-side AC firewall sliced from a '69 Lemans. Using the factory stamp steel: 1) positioning the template was made easy by lining up features common to both firewalls (no guesswork), thus making all openings/closings/modifications dead-nuts on; 2) donor metal is required to fill certain openings in the non-AC firewall, and the AC firewall provides these necessary pieces; and 3) the opening for the AC evaporator has a formed lip around it, something a paper template would not show well but easily duplicated having the AC firewall piece. Parts cars were plentiful back when I did this but maybe not so much now. However, because the firewall is Body by Fisher, at least the passenger side would be shared by the four GM Divisions - Chevelle, Cutlass, Buick, GTO; my donor AC firewall section came from a '70 Chevelle. And possibly '68 to '72 are the same but our Forum buddies can confirm or dispute that. Anyway, I used a cutting torch to do the slicing... at the center above the tunnel, then across under the lip of the cowl, and then on down the side and below the AC openings.
Thought I would share this approach as it had a very good outcome for me. Good luck! Gary in Tucson.
Old 02-15-2021, 02:05 PM
Hey... some correction to what I wrote yesterday about my firewall conversion to AC. No, the donor AC firewall did not come from a '69 Lemans AND a '70 Chevelle... as I was writing and nearing the end, I remembered the donor was a friend's bare body '70 Chevelle. My initial thinking it was the Lemans was because that was the car I got the entire AC system from, inside and under the hood. That car was still much intact and the owner didn't want the firewall sliced. Good grief, only did this 30 years ago... yikes!
