Asked in post number 8 but it's still not clear. I presume the testing was performed on a engine dyno and not a chassis dyno.
A water brake engine dyno like a SuperFlow needs to be set to operate in a certain rpm range based off the torque the engine is producing. After some initial pulls and adjustments to the brake, you start testing at a certain rpm. More often than not at about 3000 rpm and up. "Starting engine dynamometer pulls at low rpm is hard on the dyno and hard on the engine. Today, engine dynamometer testing is an integral part of many HOT ROD engine buildups and product tests. Typically these tests start no lower than 2,800 rpm, and often higher." https://www.hotrod.com/articles/dyno...often%20higher. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
37 Pontiac Sedan 455 700r4 94 Firehawk Supercharged 5.7 LT1 6spd. 71 GTO base 400 A/T 97 F250 7.3 turbo diesel |
Putting the engine in a 1968 Lemans I've had about 20 years. Was on the road about 8 of those. Doing a frame-off resto-mod ala mid '70's look, TKO-600, Ford 9", tunnel ram, big & littles, one piece fiberglass tilt nose, jacked up, white interior, tilt steering column, Grant steering wheel, Jensen door speakers in my new white door panels, Kraco under dash 8-track, and all the extra gauges outside the windshield. LOL Got side tracked with a 1948 International Box truck I am rebuilding for my brother. Have not touched the '68 in 4 years, but I have been purchasing a boat load of parts that'll make it quick to put it all back together. The body is back on the frame. |
