1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot 1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @164 3500+lbs 10.5W's SOLD! 1964 421 GP-Sold 6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold |
I’ll update this thread in a couple months. I got the 2 TA seats for $300 delivered from a local yard. I received the samples from SMS and the Comfortweave is the real deal woven vinyl, not the heat stamped repop stuff Legendary and PUI are using. It’s pricey though at $185/yd.
I used them in the past too.
Well it should look sweet, keep us posted!
Soooo....paused on the legendary kit last year and revisited it a month ago. Ordered the Ralley kit and when it hadn't shipped after two weeks I called. ...and 9 months out (still) SMH. Guess I should have ordered this LAST year lol. At least my seats are in great shape and I'll just wait.
So if anyone is considering these, expect to still wait.
They only sell the material.
Curious how many yards are required for 68-72 GTO bucket/bench...
I'm doing my Firebird inserts in perforated vinyl with the surroinds in grained vinyl. I bought 6 ysrds of perforated and there is no room for error if I make a mistake. I bought 8 yards of grained. Your back seat is larger.
If you make rough measurements of your seat panels. You need to allow for an extra half inch around the perimeter of each piece for sewing. And you need to know which direction the vinyl stretches. There is a place by me that sells surplus OEM vinyl. I paid $7 per yard.
If I sent the comfort weave to a place like Legendary, they can use material they have for the rest, and just use the SMS material for the inserts. But. That would probably be like a year+ lead time.
I bought complete seats from PUI, and not only is the shape/foam boogered up, but the comfort weave insert look like garbage. I sit so high and forward on those things I can't stand it. It's like they stretched material over a beach ball, that's how raised the seat pan and backs are. I'm going to have to do something about it, it's awful. Dang thighs rub the bottom of the steering wheel, that's how bad it is. And the comfort weave is just a flat stamped piece of vinyl, no ventilation. Horrible. .
A lot of times the repop foam is just too thick. So far I completed one seat bottom and I'm satisfied with it. GM used velcro to hold down the seat trim instead of hog rings on 4th gen seats. I used hog rings but had to figure out a way to convert. Also, nobody reproduces the foam, so I had to patch and trim. 4th gen seats are not known for durability, crappy materials and construction. The was the LH seat, worst of the 2 as far as wear. Off to do the rest.
The Following User Says Thank You to HoovDaddy For This Useful Post: | ||
