Old 05-12-2022, 02:25 PM
jhein's Avatar
jhein jhein is offline
Originally Posted by Captain Obvious View Post
I'd ask him; tell him what it is. If I were a builder I'd be pretty stoked to be able to input exactly what I want for a curve in, rather than dealing with weights and vacuum stuff. Plus I'd get to try out the tech for free. The interface is super easy. Or maybe he's old school and isn't interested, which is fine too.
He's definitely old school. But, he builds a lot of motors and has all kinds of customers so maybe he's done them before. But I think you're right. It would be a lot easier to make adjustments with this rather than changing springs and weights. I'll give him a call and talk it over.
Old 05-12-2022, 05:03 PM
ta man ta man is offline
Personally I would let the builder do what he wants, he may want to keep it simple, use the original distributor and do a few pulls..you aren't going to find any magic horsepower with the new distributor.Time is money. But after is time to play with the tune in the car on the road and set it up for drivability, power etc..that may take a while to really dial it in.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer
The Following User Says Thank You to ta man For This Useful Post:
Old 06-05-2022, 08:15 PM
lovedemnewfies's Avatar
lovedemnewfies lovedemnewfies is offline
So I just installed the small cap version on my 65 GTO 389 4 speed no A/C car with 4:11 rear gears. Cam is an 068 grind running Tri-Power. Still need to do tuning with it but install went smooth and startup was quick and easy. Question for those who have used this distributor is running a factory tach. It’s off by approx 200 rpm. Worked correctly with points. I have the tach currently connected to the - neg side of coil just like when I was using points. I know it has something to do with how the factory rally gauge was manufactured and is not compatible with modern units. Question is can a Tach Adapter work to correct the issue? Something like this
https://www.allzim.com/store/tach-ad...e-adapter.html
Thanks for any help.
Old 06-05-2022, 09:23 PM
Formula jg Formula jg is offline
Was there a resistor wire in the original points setup? It can cause some weird issues if you use it on the Progression distributor, if I recall there is a special note in the installation instructions not to use a resistor wire for power to the dist.
Or alternatively contact Theodore at Progression he quickly resolved an issue I had and another my brother had, great customer service.
The Following User Says Thank You to Formula jg For This Useful Post:
Old 06-06-2022, 09:44 AM
I ran a new dedicated 12v power wire. The distributor is the only part tied into the new power feed.
The Following User Says Thank You to lovedemnewfies For This Useful Post:
Old 06-06-2022, 12:31 PM
Captain Obvious Captain Obvious is offline
My tach is also off by a couple hundred RPM at 3k or so. Definitely less so at idle. No resistor in wire, new wiring harness was installed in the car that was built for HEI, so full 12v.
1970 Lucy TA | 461 | M20
Old 06-06-2022, 01:45 PM
So I called progression ignition and their answer was that the tach was off and that the grey wire off the dizzy wouldn’t have enough power to run the factory tach. So I guess I need to have the tach refurbished to have the “guts” installed to make it work.
Old 06-25-2022, 03:30 PM
livstrong livstrong is offline
Originally Posted by Formula jg View Post
461
6X4 approx. flow 250cfm
850 MD w/annular
T2 w/1” tapered 4 hole spacer
700R4 w/lockup
3:42
Crower solid flat tappet approx. spec w/1.65:
244/252@50
0.525/0.551
112 LSA
91 Octane/ 0% ethanol
After a lot of testing (still not done though) heres the best map so far with my combo.
Thanks for a great start as my combo was close
461
6X4 heads
770 Avenger
1/2 inch spacer
Super T10 4 speed
3:55
XE268H camshaft
94 Octane
Old 07-06-2022, 03:47 PM
Default Table
461
6X4 heads
770 Avenger
1/2 inch spacer
Super T10 4 speed
3:55
XE268H camshaft
94 Octane
After getting some time to continue playing have added a few changes
The Following User Says Thank You to livstrong For This Useful Post:
Old 07-06-2022, 05:45 PM
To assist in the tuning I like to do a screen recording of the table on my iphone while driving. The key is to drive the same route and same throttle pattern each time so your not scratching your head when comparing screen recordings.
The Following 2 Users Say Thank You to Formula jg For This Useful Post:
Old 08-01-2022, 06:42 PM
Imlern02, as requested sent you a couple of tables.
Old 08-07-2022, 02:42 PM
I just ordered one today, it will aid with my street/strip testing and tuning.I'm still trying to fine tune my combo..driveability, mileage and power
Old 08-17-2022, 08:13 PM
I just sent maps to those couple of members that pm’d me.
Old 08-18-2022, 10:13 AM
wbnapier wbnapier is offline
Would you mind sending me a timing map as well? [email protected]
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 08-18-2022, 10:50 AM
Ok, sent.
Old 08-18-2022, 12:08 PM
Formulajones's Avatar
So has Progression addressed this issue yet?
Sending a perfectly good working factory tach out to be modified is not really an option.
https://youtu.be/XqEydRRRwqE
Old 08-18-2022, 01:22 PM
Nothing received... I clicked the "Saved Tables" then the "Cloud" icon, but no recent shares. Maybe it takes a while.
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
  #38
Old 08-18-2022, 03:56 PM
Not to my knowledge. Guess I’ll just live with it.
  #39
Old 08-18-2022, 04:08 PM
Shucks. I would think they could do something to correct it that isn't overly complicated. With todays tech and electronic gadgetry it should be solvable without sending the tach out to be modified in some way.
I've had (and still have) these factory tachs work fine and read very accurately with MSD stuff and older Accel stuff and even aftermarket EFI systems. So not sure what Progression Ignition is doing to make the tach read incorrectly.
  #40
Old 08-18-2022, 05:45 PM
wb, I resent the map.
