Old 09-30-2022, 12:47 AM
77 TRASHCAN's Avatar
Glad to hear Cliff is still doing this!!!
Shut it off
Shut it off
Old 09-30-2022, 12:58 AM
dataway's Avatar
dataway dataway is offline
Might have had a few things freshened up when the cam chain was done but that's no crime. Notice it still has the original control arm splash shields, and the arms themselves look like a car that was kept inside most of its life.
Old 09-30-2022, 07:31 AM
scott70's Avatar
scott70 scott70 is offline
I know of a 70 white judge,,,one owner,been sitting in a shed since the 80's..Its about 40 minutes from me. I had the owner do some work at my house in 2004 and he still had it. He has passed since then and his son owns it now. Ive left messages if he's ever interested in selling it but no response. This summer i talked to a guy that knows the son and i asked about the judge. He said its still sitting there in the shed.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 09-30-2022, 08:20 AM
Half-Inch Stud's Avatar
How rare are those lights ? I have one........
Rare for 69-70 GTO (like where is the mercury switch) Only slightly different with mercury switch, and on the hood, for G-body.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
Old 09-30-2022, 11:03 AM
HWYSTR455's Avatar
Very nice! Auto or manual?
Old 09-30-2022, 11:39 AM
Jason67's Avatar
Jason67 Jason67 is offline
Automatic based from the carb pic.
Jason
Old 10-01-2022, 08:33 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Yes, auto trans car. I was able to do the job while he waited despite the fact that ALL the threads for the fuel filter housing came out with it! The carb had other issues from previous "tampering", which most folks call "rebuilding". The seal was off the pump and wrapped up on the return spring under it. Choke pull-off wasn't holding vacuum either. So between no accl pump and not unloading the choke of a cold start it was nearly impossible to start and difficult to drive. He'd been dealing with that at least 20 years, which probably kept the mileage down even more.........
ID:	599658   Click image for larger version
The Following User Says Thank You to Cliff R For This Useful Post:
Old 10-01-2022, 09:55 AM
unruhjonny's Avatar
You know what just occurred to me;
I bet that if a book was printed, with a minimum of text, but just photos of legitimate "survivor" GTO's, Firebirds, Grand Prix's and the likes...
1970 Formula 400
The Following 2 Users Say Thank You to unruhjonny For This Useful Post:
Old 10-01-2022, 05:48 PM
dataway's Avatar
Yep, a pictorial reference book. With enough photos you'd be able to spot most everything that was right or wrong by comparing them. Probably easy to put together too, wouldn't have to make a bunch of claims about "correct" or not ... just print the photos and let knowledgeable readers make the decision.
Old 10-05-2022, 12:53 PM
CDub76's Avatar
CDub76 CDub76 is offline
Very nice! Thanks for sharing. I vote in favor of a pictorial reference guide as well.
Old 10-05-2022, 01:28 PM
Tim john Tim john is offline
He was fortunate to end up at your place for service, perhaps your expertise gives him added confidence to enjoy his car more often. Thank you for helping him out Cliff, very well done.
Tim john---
Old 10-05-2022, 01:55 PM
cohopefull cohopefull is offline
Default Base model ‘70 Formula
Originally Posted by unruhjonny View Post
very cool!!
As someone who hopes (dreams?) to one day own an original/unmolested original Pontiac of this vintage, it's nice to know they are still out there.
Thanks for sharing this Cliff!
I saw your profile and noticed your base model Formula. I also have a 400, 3 speed , no power anything, AM radio and a few other options in Lucy blue, standard interior. So you’re not alone! Kevin
65 GTO Tri-pwr 4 spd, 69 GTO 4spd. Both Stock.
The Following User Says Thank You to cohopefull For This Useful Post:
Old 10-05-2022, 02:42 PM
jhein's Avatar
jhein jhein is offline
Sounds like a cool car. I'd love to see some pics!
So as not to hijack this thread you could post them here: https://forums.maxperformanceinc.com...19#post6364419
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
The Following User Says Thank You to jhein For This Useful Post:
Old 10-05-2022, 03:22 PM
My apologies for hijacking the thread, I thought I was responding to an individual. My bad.
Old 10-05-2022, 03:30 PM
jhein's Avatar
Nah, your post is great! Just wanted to see pics!
Old 10-05-2022, 03:58 PM
I bet he’s going to be so much happier with his car! Too bad he didn’t visit you sooner!
Old 10-06-2022, 08:34 AM
Cliff R's Avatar
I'll bet he'll put some miles on it now that it's running like it should. I can't imagine trying to drive a car with a bad choke pull-off and accl pump in the carb. It would be nearly IMPOSSIBLE to start, and "blubber" till the choke opened the flap some, then hesitate every time you pushed on the gas pedal........
  #38
Old 10-06-2022, 09:40 AM
MUSLCAH MUSLCAH is offline
All I know is that my Cliff Q-Jet rebuild has impressed everyone that rides in the 67 GTO...it runs like its hairs on fire !
  #39
Old 10-06-2022, 11:10 AM
turbo69bird's Avatar
Shouldn’t the under hood lamp be on the hood on a RA car? Or is that just bird?
BTW really sweet car a real time capsule , would be great to see detailed pics of everything even though I’m a bird person I still like to see any original Pontiac and study things. It’s so rare to find things original and undisturbed I wish more people would post pictures .
960 HP @ 11 psi, 9.70 at 146.
  #40
Old 10-06-2022, 11:22 AM
jhein's Avatar
If someone were to take photos, I think it would be better to have them posted online, like in a thread rather than a book. That way you can download the pics and then zoom in as needed to see better. Maybe that's just my poor vision as I get older...
