Old 06-21-2023, 09:17 AM
tanksteve tanksteve is offline
Originally Posted by chuckies76ta View Post
Any chance you could post a few pics of the front and back of the converter? I ordered a 9" inch from them and had the same issue your having and I had to send it back to be revised. It cost me shipping for their mistake. Wasn't happy about that. They had to change the back cover. Thanks.
here are the pics. I rotated the converter against the back of the flexplate so i can see where the bolts were hitting
ID:	614567   Click image for larger version
Old 06-21-2023, 09:21 AM
spectramitch's Avatar
spectramitch spectramitch is offline
I just talked with a guy at Coan again and it sounds like what is happening is most converters are made with BBC in mind. Those take a 7/16" bolt with a super short head. The pontiacs have a 1/2" bolt with a thick head. So he pretty much told me that I needed to step up to the billet front cover with a deep dish for an extra $400. No way im doing that. It looks like Fly-wheel bolts for a pontiac have a thin head but they have a shoulder on them. Im wondering if that might be an option. OR Mopar flexplate bolts are 1/2-20 and have a short head. But the thread length is only .500"
Old 06-21-2023, 10:19 AM
That really is infuriating that Coan wont own up to their mistakes. I looked at flywheel bolts also. But as you said, shoulders are too long including the ones made by Mr Gasket.
Old 06-21-2023, 10:25 AM
PAUL K's Avatar
PAUL K PAUL K is offline
You could use a low profile button head screw. That would sit lower than a factory BBC bolt.
Go fast, see Elvis!
Old 06-21-2023, 10:31 AM
PAUL K's Avatar
Originally Posted by tanksteve View Post
That really is infuriating that Coan wont own up to their mistakes. .
IMO if one sells a torque converter advertised to fit a Pontiac, then says it doesn't fit because it's not a Chevy the torque converter isn't really for a Pontiac.... It's seems Coan has moved back in time fifty years. Their torque converters used to fit Pontiacs without issues. I've used and sold more than a hundred of them.
Go fast, see Elvis!
Old 06-21-2023, 01:12 PM
misterp266's Avatar
Perhaps you could add a mid plate, even if you just used it as a spacer and didn’t mount it to the frame, and then space the converter accordingly to maintain the proper depth in the transmission.
https://www.ebay.com/itm/23491336073...BoC8mUQAvD_BwE
" Darksiders Rule "
Old 06-21-2023, 08:40 PM
Brentco's Avatar
Brentco Brentco is offline
but I feel horrible about running a new engine behind a blown tranny especial in the current state of the trans community.
This deserves another LOLZ
1976 Trans Am Buccaneer Red
468ci, 10.5:1 CR, 87 CC RPM CNC e-heads, HR 282/288, 230/236, 561/.573 lift, Johnson Lifters & HS 1.65 Rockers
The Following User Says Thank You to Brentco For This Useful Post:
Old 06-22-2023, 05:44 AM
How much were your bolts contacting by? Were you using the 5/16 or so sized thick head?
Old 06-22-2023, 10:30 AM
I would say the contact is around 1/16". And yes i was using the bolts with head about 5/16" thick (stock bolts). I found ARP bolts have a slightly thicker head but have a smaller diameter head, which helps in my case.
Old 06-22-2023, 10:33 AM
chuckies76ta's Avatar
I remember that. If I recall correctly they wanted you to pay for their converter not fitting properly but then came to their senses. Did you get an explanation why it didn't fit initially?
Hi Paul. No never did explain why it didn't fit. Rep told me they had no issue with these back covers on Pontiacs. They changed it at their cost and it cost me the shipping both ways.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick.
Best so far 9.95@135 mph. 1.39 60 ft.
468 with KRE D-ports, Doug headers, 3" Exhaust
950 Quickfuel.
Old 06-22-2023, 10:37 AM
Thank you for posting pics. That's the same back cover I had issues with that they changed. Here are the pics before they changed the cover on the back. I will never deal with Coan again.
ID:	614653   Click image for larger version
950 Quickfuel.
Old 06-22-2023, 10:46 AM
Not to tell you what to do, but He wanted the cost to change mine also, and I said no way I'm paying for your mistake. We went back and forth and he finally agreed to change it at their cost. I was still pissed at freight cost. He would also not refund my money when I said I'm returning it. He said it's a custom converter so no refund. You can use me as a reference if you want. I'll provide you with my order number to show what the cost was. Let me know.
950 Quickfuel.
Old 06-22-2023, 11:03 AM
Pics of new cover. I included the numbers on the converter you can share with them. Coan
ID:	614665   Click image for larger version
ID:	614666   Click image for larger version
950 Quickfuel.
Old 06-22-2023, 03:59 PM
Dragncar Dragncar is offline
Sounds like Coan is a no go these days. What a terrible experience.
Lane-PTC. Great guy, knows Pontiacs.
I am just about done fitting a Alston .100 thick mid plate in a stock A body frame right now. That might take care of these problems with those Coan converters.
The mid plate is not very big by the time you are done chopping it up to fit. needs trimmed for whatever headers you are using.
Old 06-22-2023, 09:21 PM
PAUL K's Avatar
If it's a "custom" converter that means it's made for a specific application. If it doesn't fit that application that means the vendor failed. Most likely if you paid with a credit card and filed a dispute they would be given the option to correct their error or refund the money.... That's probably why they caved and fixed Chuck's converter.
They seem to be aware of the issue using their product in a Pontiac. They should go back to their old ways, rather than make excuses and keep raising prices.
Go fast, see Elvis!
Old 06-22-2023, 10:26 PM
slowbird's Avatar
slowbird slowbird is offline
But that's just not how America works now
The Following User Says Thank You to slowbird For This Useful Post:
Old 06-23-2023, 07:49 AM
chiefbigb chiefbigb is offline
Trans specialties told me they have a different front section for BOP engines. The shelf convertors are Chevrolet based. I had this same issue but saw it when I was installing the trans. The box the correct one came in had BOP written on it.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
  #38
Old 06-28-2023, 12:20 AM
I installed this new Coan converter to day and it fit perfect. The play from the converter to the flexplate is around .134
My ARP bolts from flexplate do not hit converter.
950 Quickfuel.
  #39
Old 06-28-2023, 12:22 AM
Have you received any other info from Coan on repair?
950 Quickfuel.
  #40
Old 06-28-2023, 08:31 AM
PAUL K's Avatar
What a concept.... So we know for sure they still have the ability to make a converter that fits a Pontiac.
I hope the new converter exceeds your expectations.
Go fast, see Elvis!
