Old 07-28-2023, 11:26 AM
Stan Weiss's Avatar
Cam is a older Comp 300B, 265/276 @ .050". LSA is 106, ICL 106.
Wow can you imagine how fast this would run with a "non-stinky, eye friendly, don't throw it down the hill behind the shop" 114 LSA ......LOL
But all seriousness good job Brent. We need all the Pontiacs we can get representing us at the track.
Stan
Pontiac Pump Gas List
Old 07-28-2023, 11:57 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Love the humor, and for sure I deserve some pokes in the backside on occasion when it comes to cam stuff.....good thing I have my big-boy britches on today so it bothers me not in the least.....
Anyhow, the conventional wisdom with all engine builds are to choose the the cam for the CID, head flow, compression ratio and USE OF THE VEHICLE.
Can't argue the results here considering how simple the combo is and not using a lot of exotic parts to get er done......
Anyhow, OUT of here for a long weekend and to be there for my grand sons birth in a few days.....have fun gentlemen, even if it's at my expense!.......
The Following User Says Thank You to Cliff R For This Useful Post:
Old 07-28-2023, 12:40 PM
Stan Weiss's Avatar
Originally Posted by i82much View Post
Isn't there some conventional wisdom that a shorter stroke tends to benefit from a tighter LSA?
I also wonder about how the conventional wide-LSA wisdom for cams in the 230-240 degree range might change as you increase duration even for the longer stroke combos, I mean I run OF on a 112 in a 4.25 stroke combo, would I be better off on a 106 or 108 if I had a 250+ @ .050 cam?
It depends. Let start with. Street or race only? What kind of vacuum do you want at idle. The tighter the LSA for the same lobes the less the idle vacuum will be.
Stan
Old 07-28-2023, 12:42 PM
Stan Weiss's Avatar
Cliff,
I agree.
Stan
Old 07-28-2023, 06:11 PM
Cliff R's Avatar
Glad we agree on something.
I think that's a first.
That calls for a celebration (I'm always looking for a reason). Gonna whip up an Old Fashioned made with Bulleit Barrel Strength and smoked with cherry wood. I may have to have more than one they are so good!......
The Following 2 Users Say Thank You to Cliff R For This Useful Post:
Old 07-29-2023, 10:31 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
My copy of John Schloe's 69 RAIV 400 stocker cam is 274/274@ 0.050! Probably not a good idle or work power brakes But got the car in the 10s way back when.
Skip Fix
Old 07-29-2023, 11:58 AM
Vid's Avatar
Vid Vid is offline
That sounds like a damned fine cocktail! See you on the bourbon trail!
