Originally Posted by tooski
Mine is similar to the Big Red/Torin one in grivera's post. I've done a few outs/ins with it. I did not lube the threads. I will do that the next time. For speed I've always used an impact on it. The only problem I had was the drive nut was eating into the thread support bracket. I just installed a heavy washer between the nut and bracket on each end. I took the handle off so I can drive it from either end. The two problems which have already been stated is the reduced lift travel and once a certain height is achieved the leveler contacts the hoist beam.
When you see the damage an impact does to the hex heads, just think of how much abuse those grade 2 threaded components are having done to them.
Using a ratchet will lengthen their life immenseley over an an impact, yes I realize the impact is quicker, and easier, but you're slowly destroying the threads.
My experince was with a strut compressor, and an internal coil spring compressor, both failed from using an impact on them. I saw the aftermath, it was someone else both times that experienced the failures. The manufacturers say in the directions not to use an impact on any of these type of tools. Spring, and strut compressors can kill someone when they fail.
An engine leveler isn't as critical, but someone can still get injured, or parts can get damaged due to failures of the threaded components.
I hate using engine cranes to R&R engines, I've never even owned one. Been using chainfalls suspeded from above for 55 years.
I've posted this before, but even #2 grade 5/16" fasteners are about 1200# each, so 4800# for 4 of them. I doubt anyone is lifting a 4800# Stratostreak engine, and transmission combo. Even using an aluminum manifold you're fine, as long as the fastener is screwed in roughly 1 inch into the aluminum hole, you're still just under 5000# capacity.
