Old 12-21-2024, 01:17 PM
burd burd is offline
ECS Automotive Concepts produced the RT decal at one time and may still have it, just not show it.
https://ecsauto.com/collections/gm-d...34709550203041
Member burd states he lent his PL decal (or PF, W72, not sure which) to Jim Osborn Reproductions and had them reproduce it correctly (I kind of doubt it, but who knows).
https://www.npdlink.com/product/air-...ro/216680/8213
https://www.npdlink.com/product/air-...m-repro/216703
Osborn did mine, it’s available at Ames. . I have one at Osborne now too to do.
Old 12-21-2024, 01:37 PM
A friend made me the decals for the carb, coil cap, booster, power steer pump, master, and the ac solenoid
No one has the one on their carb anymore
Old 12-24-2024, 12:15 AM
Verdoro 68's Avatar
Because you're not doing it the way I think it was done.
I think it was a three stage silkscreen process.
Blue framework, red framework and changing artwork (filter number, pick code and part number).
I'm not so sure about that. I have an original from '74 which is done on a thicker laminated decal material. I can tell for sure that one definitely isn't silk screened.
A two color silkscreen would have also been a really labor intensive and expensive way to create hundreds of thousands of stickers. You'd be able to feel a difference in the texture of the print from the background. The color application would be more even as well as opposed to the uneven and splotchy quality on these. For example, take a look at a seriograph print or some t-shirts which are both silkscreened and show very even color. I think they were just printed as cheaply and quickly as possible, like most GM underhood decals.
For what it's worth, I'm pretty sure the air cleaner stencils weren't silkscreened either. I've been told they were originally done via a process called pad printing which explains why the quality is so variable. Silkscreen happens to be is the best way I can find to replicate that at home.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 12-24-2024, 08:51 AM
Held for Ransom's Avatar
You are probably right, they probably used some sort of offset printing. But, I don't know how that process actually works. I just know on the earlier ones, you can see dots which I thought was because of silkscreening.
https://rtruscio.com/color/lithprnt.htm
So long, farewell.
Old 12-24-2024, 12:44 PM
Kind of like the stamps grocery stores used to use to stamp prices on cans and stuff.
Rubber pad with design picks up the ink then flips over and stamps the item.
Except rolls around probably on cylinder.
