My problem is only at idle. The cooling system seems to be up to par for a non ac application it just can’t sit in traffic with the air on. At some point I have to roll the windows down and turn off the air which to me defeats its purpose. Where should I start with the timing?
Since it happens at idle I'm guessing you probably don't have much idle timing in it. Extremely common. I see this more than any other scenario. Contrary to popular belief most of these hotrods really like 28-30 degrees of idle timing. I'd start there. |
The radiator is sealed to the support with HVAC strip foam but a pool noodle may work better
Since you say that the temp creeps up only at idle, I have the same question that HWYSTR455 asked: What is the actual timing at idle? and what rpm is idle?
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Royal Pontiac (Dealer# 07-679) 70 Formula 400/auto |
That AC seal kit is bare minimum to have in place, and if there are areas that those seals don't cover or work well, THEN you use the noodles.
In some cases, like when you go to electric fans etc, then you are forced to use other methods, such as the noodles. Many times when a car is disassembled and painted, the seals are not re-installed. Be it that they are destroyed & unusable, and/or the owner didn't specify that they ensure they are installed. Sadly tho, many of the seal kits either don't fit well or the attaching hardware is less then, um, optimal. .
I have MSD with a 6AL box. 28-30 with vacuum or just from the distributor?
I usually set it up with initial (from distributor) at 14 or maybe as much as 18. Then vacuum advance adds another 10-12 or maybe even more depending on where initial is.
The two together will give you 28-30 degrees idle timing is what I start with. So you have to fudge initial and vacuum around to get that number. I have to modify the vacuum cans to achieve what I want. Of course I also have to modify the distributor breaker plate to get initial where I want. On an MSD it's easy, it comes with bushings that bolt in. I typically use the black bushing (largest) and sometimes on really radical stuff I make my own bushing to bolt in for a couple more degrees if needed. Last edited by Formulajones; 08-20-2025 at 08:02 PM. |
Damn I wish you were closer. I already put the black bushing in when I got the distributor. It had the blue bushing in it. My vacuum advance is supposed to be adjustable. I haven’t turned it up because the way it’s positioned I can’t get the wrench in there. I may try to make one. Might have to bite the bullet and pull the distributor but I am reluctant to do that because it has run so good lately.
So here is my 65 . Look at all the gaps around the radiator that need to be sealed.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
I have every gap I can find plugged
Good! I did look at the AC core support yesterday while at the shop and yes on the sides it has the rubber flaps.
One of the kind members on here was good enough to sell me a factory lower radiator support basically like the Cold Case conversion except it’s from a factory piece.
| The Following User Says Thank You to 64speed For This Useful Post: | ||
It would be wise to first off buy the radiator you’re going to use, along with the rubber insulators that the radiator sets into in the bottom. Also the top clamp and rubber insulator.
These items will assist your competent welder/fabricator to fixture the new bottom piece in place. Removing the old bottom piece carefully is key here so as not to damage the upper piece you’re going to attach to. A nice flat welding table to use to keep everything square is essential here. Tack weld it and check everything for proper positioning before the final welding. This will not be a simple or inexpensive endeavor. Your neighbor down the street with a welding machine who’ll do it for free isn’t an option here.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
I already have the bigger saddles etc as I am using the exact cold case radiator that I will be using again albeit in the larger size. This will be done in the car so I won’t be able to lay it out on a welding table.
You asked how to do it but I guess you already have your own plan.
Good luck.
No I don’t have a plan. That’s why I asked. You laid out a plan implying it was going to be done with the core support on a bench. Maybe I’m mistaken in thinking this can be done in the car?
Pretty sure it can be done in the car, but you won't have enough room to make it look good.
| The Following User Says Thank You to HWYSTR455 For This Useful Post: | ||
It can be done in the car. Back in the 1980’s me and a buddy welded-in a 4-core lower section into my 66 GTO. Cut it from a junkyard core support. Not that difficult really, just drill/grind out some spot welds, weld new in place. Don’t forget to disconnect the battery before welding.
| The Following User Says Thank You to Singleton For This Useful Post: | ||
Ok I called Cold Case and asked them how this conversion was gonna be compared to using their kit. Of course they couldn’t speak to using an original piece 100% but they did say that with their kit you drilled out the spot welds on the original, took your measurements and either bolted or welded the new piece on. I can weld. Very well actually but I think I’m going to bolt it in just in case a mistake is made. As far as appearance this is a driver. As long as it just isn’t horrible and functions properly I will be very pleased. I appreciate everyone who took the time to answer and I hope if anyone has anymore guidance please step forward.
