Old 10-08-2025, 11:09 PM
GtoFM's Avatar
GtoFM GtoFM is offline
All body mounts on my 64 use cage nuts.
ID:	658433   Click image for larger version
ID:	658434   Click image for larger version
ID:	658435   Click image for larger version
Old 10-09-2025, 04:36 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Thanks to all. I finally did find a page in the GTO restoration book that showed the cage there also. At least there is already a window to get at it!
Now to attack the trunk ones!, and put back together to one next to the seat I cut a window for that was OK!
Skip Fix
Old 10-13-2025, 02:44 PM
Skip Fix's Avatar
Found the trunk ones Driver's side the cage was loose and I could jam a screw driver in to get it stabilized. Passenger side the cage was so rust I had to rear it out and use a crescent wrench on it.
Are these already present in a new trunk floor?
Name:	passenger side trunk mount.jpg
ID:	658623   Click image for larger version
Name:	Drivers trunk mount.jpg
Skip Fix
Old 10-13-2025, 10:01 PM
GtoFM's Avatar
Only if you get the braces. That is what the cage is welded to.
