Old 12-02-2025, 12:02 AM
P@blo's Avatar
P@blo P@blo is offline
Default RPM for a buck seventy five
Thanks everyone for posting. Steve, the FI bosses appear to be the same diameter just two separate instead of a single boss for two injectors. The small raised circles on the bottom of the runners look nothing like the FI bosses.
I ordered a couple intakes this black Friday. Both sets of heads from last year's sale checked out fine which lead to another purchase this year. I am sure if these heads were coming apart when used we would hear it six ways from Sunday even on the ready-to-run versions. So far guys are happy with SM.
I might pull the trigger on the main caps just yet. Feel free to update the thread if you are happy or unhappy with what you ordered.
BG you keep on keeping on
Old 12-02-2025, 11:55 AM
Steve C. Steve C. is online now
"Steve, the FI bosses appear to be the same diameter just two separate instead of a single boss for two injectors."
Noted. However the depth doesn't seem right if one wanted to drill and install injector bungs. They are 'taller' on the single plane intake.
Only opinion on my part, and formed on the basis of incomplete information.
Old information here:
Old 12-13-2025, 04:23 PM
Half-Inch Stud's Avatar
The SM DualPlane arrived. Quality look good.Looks like Fuel Injectors will fit, when centered.
If jerked any small distance off-center AWAY from flange, they will certainly fit.
Doesn't seem like the injector protrudes, but can be made flush with the runner ceiling.
Old 12-13-2025, 06:52 PM
Most searches will suggest a single-plane intake with its consistent runner lengths and port roof heights are used for a direct port fuel injection conversion.
Additionally they are easier to get all the injectors mounted at the same level, and position.
Old 12-14-2025, 12:41 AM
Dragncar Dragncar is offline
if its a Pontiac 455 I am running a single plane all day long.
Smaller single planes like the Tomahawk work really nice on a stout 455.
Old 12-14-2025, 08:38 AM
Dualplane for the low ROM TQ under load, due mostly to ISOLATION.
Singleplane: 7robs5 & 1robs2, & 3robs4, & 5robs6 of their full AIR inhale. Mitigated at high rpm.
Old 12-23-2025, 05:54 PM
P@blo's Avatar
Originally Posted by blueghoast View Post
Last year I bought some of the black roller rockers. the fulcrum roller
seamed ok but but the small roller for the valve steams seam cheap and said
only 300 lbs of spring pressure, might use them on a small hft cam motor.
I hope the gold ones are better they claim 600 pounds of spring pressure.
I'll let ya all know what there like when I get them.yesterday I bought
some more stuff 7/16x2 inch rocker studs and a 1050 throttle body.
See if it will clean mine up with them having bleeds. bunch of other stuff
ordered too.
GT
How did the gold roller rockers turn out BG?
The Following User Says Thank You to P@blo For This Useful Post:
Old 12-25-2025, 11:26 PM
blueghoast's Avatar
Been to busy with the holidays to even lool at them
I'll let ya know tomorrow after christmas.
GT
Old 12-27-2025, 11:45 PM
blueghoast's Avatar
Well got a good look at the roller rockers and they look pretty good
from what I can see, nice fulcrum and roller tip to, looks a lot stronger
then the black one's I ordered. I'll be trying them on a motor for this
summer and see how they work in action.
GT
