I think my H&S rockers are the sewing machine noise?Tom
| The Following User Says Thank You to tom s For This Useful Post: | ||
Larry, does yours so like mine?
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
Kinda?? Hard to tell.
With the hood shut I don't hear it so much. It's not the sew machine noise that I'm super bothered about even though Johnson's have always been whisper quiet but it's more about one lifter that bleeds down after a few hours of sitting. Rather than try swapping a cartridge and hope it's better and still have a sew machine I'd rather just swap in some Johnson's and fix both issues in one shot |
Are the Howards lifters any good? Nobody has mentioned them so I'm wondering if that just because there no good.
https://www.summitracing.com/parts/hrs-91466
My Half AN Injun..... |
Ok thank you, I guess these are out.
Might be of interest....
Choosing cams based on hyd intensity? https://forums.maxperformanceinc.com...ight=Intensity .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
| The Following User Says Thank You to Torquewar For This Useful Post: | ||
Remember not cams are equal. You can 2 cams each i 50 degrees from 0.006" to 0.050"
Cam1 could be 25 degrees from 0.006" to 0.050" and 25 degrees from 0.050" to 0.006" Cam2 could be 22 degrees from 0.006" to 0.050" and 28 degrees from 0.050" to 0.006" Stan
OP - in case you haven't read Butler's description of all the Pontiac lifters: https://butlerperformance.com/n-1349...formation.html
| The Following User Says Thank You to grivera For This Useful Post: | ||
The only ones on butlers' site that have pin oiling are the HLJ-A-2375SE. If you know of other Johnsons that, have it please lmk .
Those are the ones I use in Pontiac engines......HLJ's
What is your opinion about using 20/50 oil with these lifters (HLJ-A-2375SE)? Would it be a problem. They say their clearances are really tight between the lifter body and piston.
I use 20-50 synthetic with them for years without issues.
Though Anecdotal, Lee Atkinson posted on Facebook that he has used the CC Evolution lifters on several builds and has been happy with them. I asked him if he's had any tickers and he said he had one, resolved by increasing preload from 1/4 to 3/4 turn.
Not sure why you would only set preload at 1/4 turn. That's barely 20 thou basically nothing.
Instructions are specific on these. 1/2 turn for a 3/8-24 stud and 3/4 turn for a 7/16-20 stud. That's right off the paperwork that comes with these lifters. It talks about wanting the plunger about or somewhere close to the middle of travel and says travel is .125" I'm running 7/16-20 studs so mine are at 3/4 turn. I thought about going 1 full turn but when I had the covers off recently I was rotating the engine by hand and couldn't find a smoking gun. They were all tight so I just left it alone knowing id be taking it apart anyway. Last edited by Formulajones; 02-24-2026 at 05:59 AM. |
For HR lifters generally a full synthetic or a multi grade 10w50 or a 15w50 parasynthetic will work better over a conventional 20w50. Harley’s use HLJ “SE” with 20w50 oil, but the oil operates closer to 300*. They start out cold just like anything else. 10w30 is what is recommended for most automotive HLJ slow bleed HR applications.
For thicker oil most HR valving is to restrictive when cold and they may make more racket until they warm up. If the noise doesn’t quiet down with 20w50 I’d just try a different oil or viscosity. Morel’s are one of the worst lifters with thick oil, the feed to the plunger can even be to restrictive even after it is hot. Dropping back on the viscosity usually helps quiet’s them up. Last edited by Jay S; 02-24-2026 at 02:26 PM. |
Yup
Jay, I remember you saying that, so I asked Scott at butler if they ever used 20/50 with those lifters and was expecting him to say no. But he said all the time and that you can. So that confused me a bit. That's why I was asking again and was trying to find out what formularjones was using. I like those lifters because they have the high-pressure oiling and don't mind the higher price. Butler said any of their lifers are good for what I'm doing, but I also know they sell them so why wouldn't he say that lol.
