The mixture of old school transmission and new tech engine is interesting and not very common. The need for an overdrive is pretty minimal with a LS3 engine. Gas mileage will suffer a little but those engines can certainly run at 3000-3500 RPM all day. How do you like the hydraulic TO bearing? That would certainly simplify things as far as installation. It's the brute torque of a Pontiac V8 that really tears up light weight aluminum case transmissions like a Muncie. That problem is eliminated with an LS engine. I love the simplicity of a Muncie/Borg Warner trans. So easy to overhaul if there is ever an issue. Although I would love to have a TKX in my Catalina for example, the 4K+ cost has keep me in the Muncie world. Congratulation on a really neat installation.
Got the bell housing lined out. Got it on the first try! Couldn't believe it. The face runout was only .003". Got the concentricity within .0015".
I read many time that you need an extended pilot bearing with an LS and Muncie. Not on this one for sure. I think it would hit an extended. I had bought one just in case. Oh well. On the shelf it goes. Console repaint turned out good. I didn't know, until this project, that I don't have a correct '64 console. Oh well. |
Nice job...your transmission will thank you with smooth shifts and a longer life.
This is the first time I've delved into assessing a bell housing. In my younger days, it wouldn't have even occurred to me. We just threw stuff together. Lol! I was pleasantly surprised that I was able to swap the dowels out in the car. Also drill set screw holes to retain them. Thank God for my Makita right angle drill! Love that thing!!! I found a great video about removing them with a C-clamp and two sockets. Great idea. Not enough room in the vehicle. Had to use a socket and a mini sledge to drive them out. Didn't even have to remove the headers. |
the sharpy will fade pretty darn quick;
you can get a paint pen from the likes of Hobby Lobby - I would suggesting using a paint pen. I also don't mind the yellowed white knobs - it's patina for vintage aftermarket parts.
I'm a little snobby on the shift knob appearance. lol |
There's a large mounting boss on the driver's side of the bell housing. I think it's for mounting a Chevy pivot ball. Maybe Tri-5's? It makes it a real B!@#* to get on the bolt above. So, I removed most of the superfluous appendage. I coulda made it look a lot better with a 2-flute end mill. I just wanted to hog it off quickly. Not like it's going to be seen.
Back in the day and even now bellhousing alignment isn't all that important for the Muncie. The reason it's so important now is because the newer 5 speed transmissions have a different type of front bearing that is far more sensitive. than the old style, to proper alignment. When I installed my 5 speed the manufacturer wanted .003 or better or there would be no warranty. It looks like you have a new bellhousing, that had to help with the tolerances for parallel.
