LS Talk All things based on the GM LS platform engine
Old 02-15-2026, 09:38 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Default Muncie Behind LS3
I'm done collecting parts to put my old Muncie back in (M20). I'm probably done drag racing. So, the 400 turbo is coming out. I debated buying a TKX. I just can't justify the cost. I have 3.23 gears. So, it's not that bad on the highway. Maybe I'll put a TKX in later. I thought I'd share pics of the parts I've compiled.
ID:	665040   Click image for larger version
ID:	665041   Click image for larger version
ID:	665042   Click image for larger version
Old 02-15-2026, 09:42 AM
JSchmitz's Avatar
Installing the hydraulic master cylinder was more work than I had anticipated.
ID:	665044   Click image for larger version
ID:	665045   Click image for larger version
ID:	665046   Click image for larger version
Old 02-15-2026, 09:46 AM
JSchmitz's Avatar
I welded a piece onto the clutch pedal assembly to get a straight shot without a spacer.
Made my own pedal stop.
ID:	665048   Click image for larger version
ID:	665049   Click image for larger version
ID:	665050   Click image for larger version
Old 02-15-2026, 09:51 AM
JSchmitz's Avatar
The old mechanical clutch pedal hole had obviously seen some serious cycles!
My old Competition Plus shifter handle was looking pretty rough. I wanted something closer to the factory round shifter.
ID:	665052   Click image for larger version
ID:	665053   Click image for larger version
Old 02-15-2026, 09:56 AM
JSchmitz's Avatar
My old shifter ball looked pretty shabby. Almost ordered a new one. Decided to play around with restoring it. I will probably order a new one later. It cleaned up pretty good though. I cut off a 3/8" bolt for an arbor. Polished it in the drill press. I used a fine line Sharpie to color in back in. I did more after the pic.
ID:	665055   Click image for larger version
ID:	665056   Click image for larger version
The Following User Says Thank You to JSchmitz For This Useful Post:
Old 02-15-2026, 11:02 AM
Skidmark's Avatar
Skidmark Skidmark is offline
Nice work. Thanks for sharing.
72 Lemans sport 462 auto
75 Trans Am 4 speed 39k miles
Old 02-15-2026, 02:22 PM
JSchmitz's Avatar
Thank you sir! You're welcome!
Old 02-15-2026, 02:26 PM
What are you going to use for the speedo signal to the PCM?
Old 02-15-2026, 02:45 PM
JSchmitz's Avatar
I have an inline speedometer cable one for the 400 turbo now. Have to look up brand/type. Don't recall.
Old 02-15-2026, 02:51 PM
JSchmitz's Avatar
Doing some console repair as well. two studs were broken off. I epoxied some 1/4-20 S.S. SHCS on there. Used Devcon epoxy. The stuff is insanely strong!!!
ID:	665080   Click image for larger version
ID:	665081   Click image for larger version
ID:	665082   Click image for larger version
ID:	665083   Click image for larger version
Old 02-15-2026, 03:02 PM
JSchmitz's Avatar
I have some questions about 64 4-speed consoles. Should probably post in another area. But will start here. I've owned my '64 GTO since '85. It came with this console in it. I always assumed it was the correct one. Then I saw some pics, on here, of an unrestored '64. It had a different bezel around the shifter hole. Basically a one piece top vs. separate bezel. Did all '64's have the one piece top? Also, were all painted the blue color on top and black on the base? I'm gonna try the blue and see how I like it. Looks pretty damn sharp!!! Do I have a '65 console or some other year? Some butcher hacked up my bezel. Guess I'll epoxy a piece on there and body work it.
ID:	665085   Click image for larger version
ID:	665086   Click image for larger version
Name:	GTO Console 2.GIF
Old 02-15-2026, 03:06 PM
JSchmitz's Avatar
I splurged on buying the clutch. I hope I'm not disappointed. My expectations are high. Any experiences with the McLeod twin disc?
Old 02-15-2026, 03:16 PM
JSchmitz's Avatar
Looks like Dakota Digital.
Old 02-15-2026, 03:33 PM
JSchmitz's Avatar
I found my console answers via Google search. Posted on another Pontiac forum. I searched here first and didn't find much.
"The automatic console was identical for 64 and 65 except for the paint trim". The 64 console top was painted bluish gray with chrome trim, the 65 was 60* gloss black with chrome trim.
"...the manual consoles shared many similarities. The 64 console top had a bluish-gray tint; the 65 had a black and chrome motif. The 64 two-piece console top used a gray shift lever opening cover that slid under the console opening with the movement of the shift lever. The console door was also chrome ribbed with gray trim. The 65 console top used a removable excutcheon painted 60* gloss black. No shift lever opening cover was used as had been in 64. The plastic console base was shared by both years and was painted to match the interior color. Parchment interiors had black console bases. The courtesy lamp at the rear of the console was serviced with the same part numbers as the automatic console courtesy lamp".
From Paul Zazarine & Chuck Robert's "Pontiac GTO Restoration Guide, 1964-1972".
Old 02-15-2026, 10:43 PM
JSchmitz's Avatar
I realized that I didn't need a speed sensor with the Holley Terminator X Max. I had the Dakota Digital sensor when I was running the 5.3 and factory PCM. It's been a while and I'm old. Lol
Old 03-13-2026, 08:06 PM
S Courter's Avatar
S Courter S Courter is offline
I did an m20 4 speed behind a 5.3 in a 67 Chevelle 300 deluxe I built a couple years ago. It turned out quite nice. Not a powerhouse but a great car to drive.
Name:	67 300 deluxe1.JPG
ID:	666233   Click image for larger version
ID:	666234   Click image for larger version
Steve
71 Pontiac GT-37 400 4 spd (sold)
71 Formula 400 turbo 400 (sold)
01 Firebird T/A WS6 auto (fun)
64 Tempest Post car LS1/4L60E (Love It!)
65 Lemans Post car LS1/4L60E (More Fun)(sold)
73 Lemans GT 400/auto 1 owner 52k miles
69 El Camino LS1/4L65E (Awesome)
70 Pontiac GTO Convertible 400/400 Original (sold)
69 Olds Cutlass S W31 Numbers matching 4Spd 3:91 one of 569
72 Post Coupe GTO 400/400 1 of 60 built 1 owner original
Old 03-14-2026, 06:33 AM
JSchmitz's Avatar
Nice! One of my favorite colors!
I'm getting closer. Gotta get the bell-housing indicated a little better. It's about .012" out. Bought some Mororso .007" offset dowels. Hopefully that gets it in tolerance. Also measure for throw-out bearing shims...
Old 03-14-2026, 06:43 PM
gtospieg gtospieg is offline
You should check the bellhousing for parallel before you check for concentricity.
Old 03-15-2026, 07:18 AM
JSchmitz's Avatar
Good suggestion. I'll check that too. I would expect parallel to have a lower chance of discrepancy. I did check it with a light to make sure it was perfectly mated.
Old 03-15-2026, 08:41 AM
JSchmitz's Avatar
Also suggest lightly running a large stone over mating surfaces as S.O.P. People love to pry things apart. One little dent can throw things off considerably. Although this is a brand new bell housing. The LS3 block had 41k when I got it. So was only separated, post-factory, by me.
