Old 02-28-2026, 01:46 PM
Shiny Shiny is offline
I thought about cutting and welding but that sounds like more trouble than it's worth to me. I do have a miter saw but never thought it would work for metal as the rpm is a lot lower than a grinder.... noted!
So shops can't do mandrel bends? If not, will the "squish" be small on such a small bend?
Old 02-28-2026, 03:21 PM
Most shops cannot - none in New Mexico did, and here in Portugal? lol
Yes, squish is the same whether 2 degrees or 90...
Old 03-04-2026, 06:38 PM
Just because I wanted to.....
Local shop bent them for free! Yes, they were squished, but no wrinkles.
I shortened and angled with a cutoff wheel in my grinder to try for a reasonable match to Scarebird's drawing (thanks again for that!).
The bend dropped them about an inch below the valance. Seems a good place for them.
ID:	665835   Click image for larger version
ID:	665836   Click image for larger version
Old 03-04-2026, 07:24 PM
You are quite welcome. That looks quite good.
Old 03-21-2026, 11:08 PM
Took me 3 passes of dinging, filler, and blocking to straighten the valance.
PO left it like this on both sides to fit those oversized 4-inch diameter tips:
I did not have too much trouble straightening and the filler is not embarrassing:
Finally got it epoxy-primed today after waiting a couple weeks for the winds and cold to stop:
ID:	666697   Click image for larger version
ID:	666699   Click image for larger version
