Old 06-04-2026, 11:39 PM
Region Warrior's Avatar
Make sure not over 12 volts.
The Following User Says Thank You to Region Warrior For This Useful Post:
Old 06-05-2026, 08:15 AM
grivera's Avatar
grivera grivera is offline
All my cars run 13.6 to 14.2 volts, including the one with a PI dizzy.
Will Rivera
The Following User Says Thank You to grivera For This Useful Post:
Old 06-05-2026, 09:38 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Interesting you said this. PI had me take readings while running at battery and cap +. ,which was 14.61 volts at battery and 12.45 at cap +. They said I have a resistor wire in place and should run power from the fuse box to dizzy. Will try that this weekend.
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
Old 06-05-2026, 11:20 AM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Default Power wire
There may be something to that.
I run power straight from fuse box to HEI cap.
Wire is oversized and soldered ends for longevity.
Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, GM HEI and Ram Air pans and RARE Long Branch Manifolds
The Following User Says Thank You to 68 Firebird For This Useful Post:
Old 06-05-2026, 12:16 PM
grivera's Avatar
I strongly suggest a SPST relay using the current dizzy wire to trigger it.
Will Rivera
