Old 07-04-2026, 03:55 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Dorman bushing is magnetic. looking through old thread Ken (Pontiac Dude) said even old ones were and no issues if a dab of grease.
McLeod has a 1380-1 Pontiac (as well as -7 extended) that are listed as oilite.
Skip Fix
Old 07-05-2026, 06:59 PM
Held for Ransom's Avatar
Back from my friends cabin. Measured the National I had vs. the NDH that was removed and they were close to each other using my 0.001 dial caliper. But, I didn't use the National for some reason (see later) other than the width was 0.352" vs. 0.354" (NDH). Real reason was 8 bearings vs. 9 on original.
ID:	672864   Click image for larger version
So long, farewell.
Old 07-06-2026, 09:23 AM
Skip Fix's Avatar
Got a spec?
Skip Fix
Old 07-06-2026, 08:58 PM
Skip Fix's Avatar
So got the McLoed today Comparison to Dorman
Dorman -actual stamped 0174523 OD 1.3795 ID 0.595 thickness 0.436
mcLeod OD 1.3819 ID 0.5935 thickness 0.351
BOTH are magnetic. In their catalog it does not list the Pontiac as oilite whereas the SBF same OD is-different ID, and some GMs. They do make a thicker one for Pontiacs.
Skip Fix
Old 07-07-2026, 07:11 PM
Originally Posted by Skip Fix View Post
Got a spec?
OE (NDH) was...
9 bearings
OD 1.3770" (34.97mm)
ID 0.5900" (14.99mm)
Width 0.3530" (8.97mm)
National was...
8 bearings
OD 1.3765" (34.96mm)
Width 0.3520" (8.94mm)
L&S was...
8 bearings
Width 0.3510" (8.93mm)
What I did use was ordered under PN 15533265.
9 bearings
Nothing else was checked at the time.
So long, farewell.
Old 07-08-2026, 12:03 PM
Skip Fix's Avatar
Dorman was snug but could push in with fingers so went with the McLoed it had to be tapped in with a little force
Skip Fix
