With a 113 lsa and 232 @ .050 it won't make much noise in a 455 when properly installed and tuned.
Once it's installed at a decent ICL and has enough timing in it, then dial in the carb I can almost make the cam undetectable in a 455 when the LSA is spread out that far and has minimal duration. The more compression the better. I did a 112 LSA roller with 239 @ .050 in a 455 with 10:1 and it idled very tame with only a slight hint of a lope in gear and made 13-14" of vacuum. Worked the power brakes and AC like a stocker. Many people haven't been happy with the RAIV cams, but they also just toss it in dot to dot and then try to run 10 degrees of idle timing and complain it's too much cam.. Yeah it's going to idle and drive like crud when done like that. |
| The Following User Says Thank You to Formulajones For This Useful Post: | ||
Another tid bit to consider when watching videos meant to share valvetrain noise.
Cell phones typically don't have fantastic built-in microphones. Often leading to degradation of audio quality. Example a cell phone recording of a solid roller set up might sound like a thrashing machine, but typicaly not as bad in person. And often louder not installed in the car itself ![]() https://www.facebook.com/PaulKnippen...7060277785407/ .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
Can't say enough about the RAIV cam in my 406. It runs terrific in any drving I use it for and it just sounds downright mean. Had to change the torque converter beause of the cam change. I run a 700R4 and went from a 2,200 RPM stall converter to a 3,000 RPM stall converter. Always had a 3.73 rear gear in it.
