#381
[TANGENT/]
There was also an obscure AC oil filter used on 1967 Pontiacs only.. ![]() 6437461 PF23
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 ![]() 2019 Canyon SLT Crew 4X4 ![]() |
#382
8 of these to a package. One set came in a box and the other in a paper envelope.
538343 0.429 All V/8 exc. Ram Air-IV & 307 NUT, ball ret 16 1969 1973 **0-25 ![]() These have the small felt standoffs built into them. And in good shape, too. 9825898 10.792 All F CAM, front door wind. guide (front) RH 1970 1974 **10-1 9825899 10.792 All F CAM, front door wind. guide {front) LH 1970 1974 **10-1 ![]() 9806086 10.792 All F CAM, front door wind. guide (rear) RH 1970 1975 **10-1 9806087 10.792 All F CAM, front door wind. guide (rear) LH 1970 1975 **10-1 ![]() Chad .
1966 Ford F250 Deluxe Camper Special Ranger Custom Paint - San Jose plant http://www.ford-trucks.com/forums/12...al-ranger.html 1966 Ford F250 4x4 Red/White 4-speed - San Jose plant 1966 Ford F250 4x4 White 4-speed - San Jose plant http://www.ford-trucks.com/forums/11...-f250-4x4.html 1971 Trans Am White/Blue 4-speed limited options - Norwood plant http://forums.maxperformanceinc.com/...d.php?t=757496 |
#383
I always thought it was funny that the MPC's had to say "front door" when listing parts for "F" bodies.
Wait, you don't have a back door on your cars? Lol.....
7811615 6.673 All V/8 P.S. exc. X/307 FITTING & ORIFICE 1 1970 1975 **6-30 ![]() 8808230 10.710 F WEATHERSTRIP (inner) (at belt) RH 1970 1975 **10-9 8808231 10.710 F WEATHERSTRIP (inner) (at belt) LH 1970 1975 **10-9 ![]() ![]() Chad .
#385
Front outer wheel bearings.
7450627 6.313 All A, F, G, X BEARING (LM11949-LM11910) (Hyatt) 2 1971 1975 **6-7 ![]() 7806232 6.500 All exc. Tilt/Whl COVER & SCREW, strg. col. lock plate 1 1969 1975 **6-8 ![]() 7806185 6.500 All exc. Tilt/Whl SPRING & BOLT 1 1969 1975 **6-8 ![]() Chad .
#386
Got any NOS grease to go with those ancient wheel bearings? Those things look like they came over on the Mayflower!!
#387
#388
I should have known! You haven't lost your bearings after all.
#389
ha-ha!
that's great! I'd wager those bearings are better quality than anything you can buy these days!
#390
Granted that one might have seen better days, but I have more that are unopened like the one on the left - should be in their wax wrappers. But, a little Gibbs spray and anything on the surface of that one race should clean right off.
Chad .
#391
Finally found a slightly more accurate shift knob. This is still the 1978? and later style. But, I do believe it to be NOS. Quite a bit different than The Parts Place reproduction that I've had for a while now. I don't know if anyone else reproduces these knobs or not.
![]() Chad
#392
Thought I'd better update my thread before the admins delete it.
I pulled out the door panels that I had Just Dashes restore back in about 1997. Sitting so long the packing peanuts had started to "become one" with the passengers side. Probably good I caught this - no apparent long term damage. This was back when you couldn't get the 1971 standard interior from Legendary or PUI. These days they sound like a good option. What do you think of these? ![]() ![]() ![]() ![]() Good enough for show or go buy the Legendary ones? Chad
#393
FWIW, I like what I see.
#394
They look good enough to me. Color looks a little dark?
#395
They look nice!
keith k 70 Trans Am RA III / T400 / Lucerne Blue / Bright Blue 70 Trans Am RA III / M20 / Lucerne Blue / Sandalwood 70 Formula RA III / M21 / Lucerne Blue / Bright Blue |
#396
How can black be too dark ? Lol
#397
If you don't want them, send them my way
#398
I agree they look a little dark all by themselves and that might be enough said. They are definitely not black. Let me share a few more pictures. Pictures are cheap so here goes.
These 1971/72 dark blue interiors are about as tough to match as the 1970 bright blue must be. Even though Seattle doesn't get a lot of intense sunlight compared to some place like California or Arizona, interiors still do fade some here and this car started out in Ohio for a few years before coming here. Here's the top side of the original sunvisors. Cloth instead of vinyl so it reflects the light a bit differently. You can possibly see the stitching around the edges is basically gone. It is definitely a bit lighter in this picture. ![]() Here's another with the door panel, visor backside, original glovebox door on that back inner part, repainted molding and part of a test panel for the interior paint. ![]() Here's the back side of the original sail panels. Again, a little lighter. ![]() Now, in this picture I've included the original panel that goes under the steering column - missing a small chunk in the lower right corner, too.. You know how bad this part fades. If Chris reads this maybe he can take a picture of his compared to other pieces. ![]() Here I've pulled back a little farther and you can see part of the front seats that are also from 1997 era, but not Just Dashes. This was the PUI offering of the time. They, I suspect, dye them from a black. But you can see how well they match the door panels done by Just Dashes. At least from my perspective. ![]() Here's about the same shot, but believe it or not this is WITH the flash on my iPhone turned ON. ![]() Another angle. No flash on the camera. ![]() Here's a close-up with the flash turned back ON. The difference between the under dash piece here is now far more obvious, but look at the back sides of the sail panels and the edging of the visors. Maybe not all that far off? ![]() Here's some of the original seat back on the new seat upholstery. ![]() ![]() Next to the even more faded under dash panel. ![]() But, not as dark as black. ![]() ![]() Trying to marry all of this together is a tough choice. Do I dye the seats and door panels a bit lighter or try the stuff from Legendary or dye some of the faded pieces to match the seats and door panels? The dash and console were also done by Just Dashes so they look the same as the door panels right now. I do also have an NOS dash pad in black that I was sort of planning on using instead of the one from Just Dashes, so I'll have to dye it anyway. Chad
#399
Jmo but the covers and door panels are way off. If it was my car I would redye the door panels and replace the seat covers. Are the seat covers PUI? I had a 72 that had Pui covers and they looked like yours. I ended up replacing them with legendary.
#400
oh wow - when I looked at those photos (on my phone) last night I didn't have a clue they weren't black...
I completely see the (dark) blue now!! Here's my take, and a slight departure from what is specifically being discussed: As I've understood it, brand new, there was colour variance in pretty much all "coloured" interiors - variance between materials and panels;; It seems to me that many cars are being over restored these days in that the colour variance is no longer being seen... Frankly, if it were my car, I'd try to discern what was normal colour variance for that colour interior of that year, and not worry if your observed variance is reasonably the same... Maybe I'm wrong, and I'm not trying to in any way disparage a car who's owner has gone great lengths to have everything match perfectly - but it seems to me, that if there was a colour variance from the factory, that seeing this shouldn't detract from the finished car.
