Old 10-25-2018, 12:56 PM
TA455HO's Avatar
TA455HO TA455HO is offline
OK, more good thoughts guys. Chuck, I appreciate your thoughts and they are PUI covers. I agree they just DID NOT hit the nail on the head with the colors. Suprising that two different vendors got fairly close to one another, but it's just not right.
Oxley at one point sent me this rattle can of DDL paint, which I think was for the metal ashtray front. I just sprayed some of that on some masking paper and I think it looks really close to correct - considering it is still glossy here.
Jonny - I agree things were not all one color and I sure don't want to make everything 100% identical. I've just always wanted to get some thoughts on these. The PUI seat covers almost show some of the black through the blue like they didn't give it quite enough coats to fully cover or something like that. Not that the color is correct anyway.
Thanks for looking and offering your advice.
Does anyone have pictures of the 1971 Legendary 201 or 211 trim code seat covers and/or door panels they could possibly share?
Chad
1966 Ford F250 Deluxe Camper Special Ranger Custom Paint - San Jose plant
http://www.ford-trucks.com/forums/12...al-ranger.html
1966 Ford F250 4x4 Red/White 4-speed - San Jose plant
1966 Ford F250 4x4 White 4-speed - San Jose plant
http://www.ford-trucks.com/forums/11...-f250-4x4.html
1971 Trans Am White/Blue 4-speed limited options - Norwood plant
http://forums.maxperformanceinc.com/...d.php?t=757496
  #402
Old 10-25-2018, 02:06 PM
weranc55's Avatar
weranc55 weranc55 is offline
Legendary covers
ID:	495976   Click image for larger version
  #403
Old 10-25-2018, 02:08 PM
weranc55's Avatar
PUI and legendary Difference
  #404
Old 10-25-2018, 02:38 PM
TA455HO's Avatar
Cool. Thanks Chuck.
I did get new foams (buns) for my car back then, but I was just looking at the buns for my car - 1971 Standard - on the Legendary web site and as I zoomed in on the foams I could see it says American Cushion Industries. Those are good cushions made by a company local to me - just over in Shelton, WA.
I just bought the 1966 Mustang standard front buns for my 1966 Ranger - no rear seat in the truck so didn't need those. They obviously use the same boxes for several different makes/models.
On the side of the boxes.
So it appears Legendary is a reseller of ACI buns.
https://www.legendaryautointeriors.c...A%221%22%7D%5D
Compare to this
http://www.americancushionind.net/pr...bird73-81-std/
Chad
  #405
Old 10-25-2018, 02:49 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
The Legendary covers looks great! assuming those with the new ACI cushions they sell? (just saw Chad's reply after I posted this) I used the ACI in my '72 and you can tell as soon as you pick them up they are extremely high quality. I'll add a pic of a small modification I made to the upper headrest portion on the buckets that made it easier for me to keep the covers smooth in that area in case that helps anyone else.
Name:	Formula ACI Cushion.jpg
ID:	495984   Click image for larger version
Name:	Formula Seats.jpg
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
  #406
Old 10-28-2018, 10:43 PM
Chad,
I'm assuming this was directed at me, so here you go. I took these pictures yesterday, with an odometer reading of 17,826. Everything in the interior is original (color-wise), with the exception of the plastic pockets in the door armrests. Mine had discolored (lightened up) over the years, so I had them repainted to match the interior. There is a little discoloration of the filler panel under the steering column and the ashtray cover, but there is very little discoloration of the glove box door. The rest of the interior plastics, (kick panels, seat backs, and the inner quarter trim panels all look good. This is probably due to the many years of indoor storage.
Originally Posted by TA455HO View Post
If Chris reads this maybe he can take a picture of his compared to other pieces.
ID:	496261   Click image for larger version
ID:	496262   Click image for larger version
ID:	496263   Click image for larger version
ID:	496264   Click image for larger version
  #407
Old 10-28-2018, 10:45 PM
A few more pictures...
ID:	496266   Click image for larger version
ID:	496267   Click image for larger version
ID:	496268   Click image for larger version
ID:	496270   Click image for larger version
  #408
Old 10-28-2018, 10:47 PM
ID:	496272   Click image for larger version
ID:	496273   Click image for larger version
ID:	496274   Click image for larger version
ID:	496275   Click image for larger version
  #409
Old 10-29-2018, 04:44 PM
TA455HO's Avatar
Chris, this is like the holy grail of 1971 201 interiors. Can you possibly get a shot of the left and right lower front floor vent grilles? I can see the passengers side somewhat in one shot but I can't quite get the details. One of the drivers side, too, would be beauty.
Thanks so much!
Chad
  #410
Old 10-29-2018, 06:19 PM
TA455HO's Avatar
The lighting seems to make a huge difference, too. If I take an example rear kick panel outside under natural lighting with the same camera it lightens up a lot. It's raining here today so there is no sunshine but you can see the difference between that.
And inside with all of the same original parts from my car, plus the repainted metal pieces from over the door and the A pillar and a chunk of headliner material that is a potential.
You might notice the inner door handle trim pieces in there. I know they are not like yours. I think we had discussed that before.
I kick myself over the seats since the covers were in good shape except for one spot on the drivers seat. Everything probably needed to be resewn at the seams, but the material was still fairly good.
Here's some I have of the original seats. Not much, but something to compare to.
I should have at least saved the original covers, but no going back now.
Chad
  #411
Old 10-30-2018, 04:22 PM
Do you mean the kick panels? If so, will these pictures do? If not, just let me know, and I will pull the car out and take more pictures (It's too dark in the garage to get good pictures unless I use a flash). Also, those newer pictures you took, the ones taken outside in the natural light, look dead-on to the color of my interior.
Thanks so much!
Chad
ID:	496503   Click image for larger version
  #412
Old 10-30-2018, 04:31 PM
unruhjonny's Avatar
If it matters, my cousin Ken is on here and goes by 'HOkenny' iirc;
He has a '71 TA, which has a completely untouched interior;
His is a code 211 car.
It's not mint, but it too will show colour differences between panels.
He's actually my mom's cousin, and as a teenager, I would occasionally hear about him at family gatherings;
Imagine just how cool it was to meet him the first time;
Me in my '70 Formula;
Him in this TA.
Maybe a love for Pontiac's is in the genes?
lol
1970 Formula 400
  #413
Old 10-30-2018, 04:50 PM
Mighty fine looking interior Chris!
Chris & Chad, question.... was the original '71 211 code comfort weave material, real comfort weave, or just embossed? the original black comfortweave seats I've pulled out of several deluxe interior '71's have all been real comfortweave. The original comfortweave covers I've pulled off of three sets of original '70 Bird seats, (black as well as sandalwood), were all embossed not real comfortweave.
  #414
Old 10-30-2018, 05:01 PM
unruhjonny's Avatar
/\ the real macoy.
1970 Formula 400
  #415
Old 10-30-2018, 05:02 PM
TA455HO's Avatar
I can't say for certain myself. The only deluxe interior car I've owned was the 219 black. I don't recall now if the seats had been redone or not, but the material was amazing. It was a definite weave and felt like if you spilled your Coke it would go right through it. I never tried. It had a certain amount of stretch to it, too. Hard to describe. Maybe Brad can take some close-ups of them? He owns the car now, at least last I had heard he still had it. The best picture I have of the seat material is probably this one. Front and back seats were all the same material. Very comfortable.
Chad
  #416
Old 10-30-2018, 05:07 PM
unruhjonny's Avatar
I came back to reply again to this:
...question.... was the original '71 211 code comfort weave material, real comfort weave, or just embossed? the original black comfortweave seats I've pulled out of several deluxe interior '71's have all been real comfortweave. The original comfortweave covers I've pulled off of three sets of original '70 Bird seats, (black as well as sandalwood), were all embossed not real comfortweave.
How do you know those '70 car s were original?
I have a set of 1970 213 seats, and I'm pretty certain they are real comforweave too...
Is there something to look for to distinguish?
My gut say those 'fake' comfortweat covers were repaired/replaced covers.
1970 Formula 400
  #417
Old 04-14-2019, 11:36 AM
TA455HO's Avatar
I've been spending some time working on getting the door gaps set. I'm going for about a 3/16" gap, but when I set that as the lower gap along the rocker then it seems a little wide at the A-pillar. Tell me what you think. I know it's a little hard to tell with the tape in the way. Yes, those are paint sticks that I put thru my planer until they were exactly 3/16". Working alone most of the time so I have to get creative.
Chad
  #418
Old 04-14-2019, 02:12 PM
TA455HO's Avatar
I've got the drivers door all snugged down so it won't move. I did put the glass in the door and the inside handle and brackets so it weighs pretty close to final weight. Hopefully the mirror, inner door panel and outer handle don't throw it off. I'm pretty happy with where it is.
The front lower gap looks bigger but it's just that the ceiling lights are shining down on there.
Chad
  #419
Old 04-14-2019, 03:13 PM
Pepi's Avatar
Pepi Pepi is offline
Looks good, nice job on the gaps!!
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
  #420
Old 04-14-2019, 08:22 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
Door gaps are way off. You're going to have problems with the bottom of the doors hitting the sills once the carpet and aluminum trim is installed. You need to get the door up higher. Spec is a lot wider than people think - 1/4". The interior door panels on early cars with the masonite arm rest are heavy so you should install them when setting gaps. At the A-pillar, set the door to be flush or slightly inward of the pillar or it will rub on the fender. For best fender gap results the door lower edge should be slightly behind the rocker panel. Here are the specs.
