Old 07-08-2016, 08:10 PM
Will Will is offline
That's good news. I'd like to use the HSD as it's stock height/carb location will be critical with my Formula hood & aircleaner. I might be able to get away with using one of those 1/4" carb gaskets, or maybe a custom 3/8" spacer.
  #442
Old 07-14-2016, 07:36 PM
blueghoast's Avatar
Originally Posted by ta man View Post
462 85 cc SD KRE 290 cfm heads,SD's "Old Faithful"HYD roller cam,1.65 Harland Sharpes,Torker 2 untouched,Wilson one inch four hole spacer,Holley 950 HP with 50 cc pump on front,Spectre 4 inch cowl air cleaner,30 degrees total timing,12 degrees intial,all in by 2800 rpm,Hooker 1 3/4 inch Super Comps.3 inch PYPES X,cone reducers into Walker 2.5 inch Ultraflows,2.5 inch tailpipes,10 inch 3200 Continental Convertor(over ten years in service now..four different 455 combos and two cars),th 350 ,3.08 rear gears
What size tire do you have on your car?
Thanks GT.
  #443
Old 07-14-2016, 08:12 PM
ta man ta man is offline
Thanks GT.
New set..275/60/15 Mickey Thompsom et pros...they are slightly larger than the old et streets in diameter and a slightly wider footprint...It looks like Saturday I will be testing the carb main body at the track to see how it works...Also Andy and Chris are going...both will rock the strip!
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer
  #444
Old 07-14-2016, 08:59 PM
MUSLCAH MUSLCAH is offline
Ta-Man.......that Canadien 11.20 ....is only a 14.56 here in the states ..with the current exchange TIMES........lol.
  #445
Old 07-14-2016, 09:36 PM
cnc's Avatar
cnc cnc is offline
Yep lookin forward to it first time out with drag radials ....need to learn on how to get the tires sticky....
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
  #446
Old 07-14-2016, 09:53 PM
Big burnout!If the tires don't collect everything on the return road they aren't hot enough!My best 60ft last time was the best burnout.....Andy's buddy Paul was running beside me!I'm hoping with the new tires I don't need to melt them to stick!
  #447
Old 07-14-2016, 10:05 PM
The way this new carb main body feels on the street..I may only run that!I will see if I can dial this new carb setup in...!
  #448
Old 07-15-2016, 09:15 AM
Pontiac Derek Pontiac Derek is offline
I would not mind giving someone a good on Porting their HSD or Really any Intake to test with.
Ernie I'm super excited to see what tires do, i do wish you would test the tires then next time test the carb, but i understand how much time it takes!
Good luck! Let me know how it goes!
Build it Right Build it Once!!!
Just another Engine Builder from the Northwest lol
  #449
Old 07-15-2016, 09:37 AM
I'm hoping the tires will hook better with less burnout...its one of those track outings where I can evaluate both...I should have measured the circumference of the old tires vs the new ones...The Pros are slightly taller..so the effective rear end ratio is lower again.....The new carb should show more mph if more cfm is needed..I tried a larger 1000hp vs the 950hp...and it did not gain at the track...but that was before the intake work and dropping the tailpipes...I'm not expecting much gain..the timeslips will tell....Andy and Chris will both lower ets easily!
As Derek knows I've only been shifting at 5500 rpm...I've had a 5700 limiter chip in my MSD for a couple years now.Since my tach is off a bit I've installed a shiftlight...so I will experiment with higher shiftpoints ...I'm also taking my 950hp mainbody..for a swap if I have time...The car may seem dialed in to some...but many little cost effective changes are being made this year..The last modification of removing the tailpipes..was great..I dropped .1 and added 1mph for free!
  #450
Old 07-15-2016, 10:25 AM
ponjohn's Avatar
ponjohn ponjohn is offline
Less burnout and 18-20lbs of air.
  #451
Old 07-15-2016, 10:32 AM
Thanks..I used to run 18 in the et streets..that is what I was thinking.
  #452
Old 07-17-2016, 01:14 AM
Ran 7 times..the last 2 a spinfest both in the 11.50's with 1.9 60fts...First 2 with the 1050 Annular Main Body..11.3424/120.84mph 1.6705 60ft,11.3611/120.19 1.6632 60ft....I decided to swap the 950hp mainbody back on ..next three runs...11.2592/121.2mph 1.6647 60ft,11.2527/121.91mph 1.6709 60ft,11.2589/122.15mph 1.6686 60ft..The 950hp carb works well...I'm not giving up on the 1050 mainbody..it needs tuning..a set of tunable metering blocks and a AFR gauge will help immensely..
  #453
Old 07-17-2016, 08:08 AM
shaker455's Avatar
shaker455 shaker455 is offline
I agree,
I need to spend a few nights at the tack with you, Andy & Chris.
You guys are welcome to come out here & hit New England Dragway.
I'm 10 mins away
Carburetor building & modification services
Servicing the Pontiac community over 25 years
  #454
Old 07-17-2016, 11:47 AM
grandville455's Avatar
grandville455 grandville455 is offline
My Opinion on the 1050 Main body, is its too much, and your loosing velocity with it, it could work with more fuel possibly, but then your over fueling the engine for what it wants, I would stick with the 950 HP...
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
  #455
Old 07-17-2016, 11:57 AM
I agree...my carb,spacer,intake and heads are all about velocity...I'm glad I took my 950hp mainbody with me..it was about a half an hour swap on a picnic table..
  #456
Old 07-17-2016, 06:34 PM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Looks like the 60' times were identical between the two main bodies but ET & MPH were less with the 1050. Could the bigger annular boosters make the 1050 body actually flow less than the 950?I I believe the QFT 1050 bodies have 1.56" venturi diameters same as a 850 Holley.
What was your 1/8 mile times & speeds?
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
  #457
Old 07-17-2016, 08:11 PM
The 950hp only has a 750body..with the 1050 main body 7.2864/96.02,7.2943/96.22 with the 950hp main body 7.2446/97.26 7.2499/97.25 7.2375/96.84
  #458
Old 07-18-2016, 04:11 AM
TCSGTO's Avatar
My mistake. I thought you had a Quick Fuel 950 that has a larger venturi than the Holley 950. People rip on the 950HP for having a 750 body but they always seem to get it done on a wide range of combinations.
There's probably more left in that with further tuning 1050 though. That it matched the smaller carb to 60' is encouraging.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
  #459
Old 07-18-2016, 01:56 PM
Yes I agree...I believe its the stock 950hp metering blocks holding it back.On the street the 1050 felt sluggish..the track confirmed it....On a positive note even with the car running slow for 2 runs it was still 11.34/11.36 at 120...
  #460
Old 07-18-2016, 01:59 PM
Originally Posted by shaker455 View Post
I agree,
I'm 10 mins away
It would be a great roadtrip!I'm about 10hrs away!
