Old 12-07-2012, 01:19 PM
Rob B's Avatar
Rob B Rob B is offline
Originally Posted by R 70 Judge View Post
Seriously, WTF is the deal with this engine? It's one problem after another
x2. I spent the time reading thru all the pages awhile back and that thing is scary!! From everything I've read and the photo's posted, none of this looks or sounds remotely like something BES would initially do in any of their builds, now what happens to it after it leaves their shop can be another story! They are local to me and I've never heard anything negative on the quality of their work and They've been around for a long time in this area. I know who I'd be pitchin a fit with on all of this.
Sad deal.
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
Old 12-07-2012, 01:24 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Sad deal.
This engine was shipped directly from BES.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 12-07-2012, 01:30 PM
Rob B's Avatar
Have you talked directly with them over this? I'm just stunned to believe that they are totally behind the build of your motor and some of the hack work pictured in your post.
Old 02-01-2013, 08:37 PM
T Syron's Avatar
T Syron T Syron is offline
If BES is going to affiliate themselves with other engine builders...they should check the work that has their name on it.
Tom Syron
Old 12-09-2012, 10:43 AM
J.C.you's Avatar
J.C.you J.C.you is offline
Has anyone else tried this McCarty/BES head bolt cooling mod? It does look much easier to do than running external coolant lines. I have serious doubts it’s actually going to work though.
Yes that is a head bolt you can see through the opening in the intake port.
Run it.......i would be more concerned about the log in the middle of the port rather than cutting thru a small amount at the head bolt.
Not to discredit...but why is the area around the head bolt darkened compared to the rest of the port wall that was hit with the common sand roll?
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
Old 12-09-2012, 11:26 AM
RAIV-Z's Avatar
Discredit who? I’m not sure why it looks like that either. Below are additional shots of some of the other ports.
ID:	305600   Click image for larger version
ID:	305601   Click image for larger version
ID:	305602   Click image for larger version
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 12-09-2012, 11:39 AM
T Syron's Avatar
Maybe you should post a few of those pictures on yellowbullet...guaranteed BES or someone who works for them or knows them follows the bullet.
I would like to their response on the main cap pictures.
Tom Syron
Old 12-23-2012, 01:35 PM
lemans411's Avatar
lemans411 lemans411 is offline
well everyone else seems to think this is ok and maybe they've had good luck with this but in my experience it has been an issue./
on a set of wenzler heads i had there was one stud that was open into the intake port. i ran it that way for a while and it was fine, but after time oil worked its way into the hole and when i would get on it it would suck that oil into the port and smoke like crazy. i took the head off and had a sleeve put in the hole and the smoking stopped. mine was a bigger opening than your pic shows but i thought it was worth mentioning
-Rob
67 LE MANS in pieces...
68 gto
84 grand prix twin turbo 496 pontiac 25.3 cage
Old 12-07-2012, 01:33 PM
cgeise's Avatar
cgeise cgeise is offline
This ******* deal is a hack job - unbelievable - I would contact BES and find out EXACTLY what there envolvement was - some one needs an asskicking over this deal
Old 12-07-2012, 02:04 PM
RAIV-Z's Avatar
I reached out to BES this morning via email.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 12-07-2012, 06:53 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
I really hope this all works out for you. You deserve a break, this gets worse everytime you post.
Are you certain that the engine wasn't delivered as is to BES and they just dynoed and tuned it?
Old 12-07-2012, 07:11 PM
RAIV-Z's Avatar
Yes, I'm sure.
On a positive note, it can’t get much worse as there is not much left to take a part. Knock on wood…
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 12-07-2012, 10:33 PM
jdw_poncho's Avatar
jdw_poncho jdw_poncho is offline
Can you just chorme plate them? I always heard making something shining makes it fast?
Sorry to see more of your engine parts was treated the same way. But the bare block I received had the same hammer marks on it. I purchased mine "unused" from someone on the board. Maybe they let each other use the same tool..... or a tool was using the wrong tool.
Hopefully a quick check says it ok?
Old 12-09-2012, 12:58 PM
GTO Dan's Avatar
Have you heard back from BES or are they not responding to you because Lynn was their client on this engine and not you? Did you pay BES directly or through Lynn? Did you work with them directly or through Lynn?
Old 12-09-2012, 01:40 PM
RAIV-Z's Avatar
Nothing back yet, I wouldn’t expect a response until at least Monday. BES was paid via Lynn. I talked to Tony a few times early on and then after the engine was delivered regarding some of issues with the heads and valve train. I worked mainly through Lynn.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 12-07-2012, 11:05 PM
Tom Vaught's Avatar
Boost Engineer
That was a BFH to make that kind of dent in the caps. Whatever happened to using BRASS tools to snug things in place?
Tom Vaught
Old 12-08-2012, 08:32 PM
mechanickeith's Avatar
Tom Vaught
Brass hammer is fine. I also use a plastic dead blow hammer with the lead shot inside. Works great. That main cap is fubar'd!!
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 12-08-2012, 10:12 PM
pontsd pontsd is offline
Thumbs down Accountability
WOW,
Wt....f happened here !! This is worse than a nightmare on elm street .
I can not understand how this could have gone so bad and have BES name or involvement
This is looking like someone has no clue, but the Bigger problem is they did , WHOEVER was working on that engine did not give one **** about it and in the end has done great damage to their reputation and BES !!
Really sad , sorry man.
Please don't delete this, as this needs answers.
Old 12-08-2012, 08:26 PM
taff2's Avatar
taff2 taff2 is offline
Looks like they let the apprentice teaboy build your engine,that is rough work.
Old 12-09-2012, 01:11 PM
John Langer's Avatar
John Langer John Langer is offline
I have been running that exact same head bolt cooling mod since around 2003. If you sleve the bolt hole it would be more of a protrusion then the bolt itself. As far as the numbering of the main caps, I highly doubt that they remachined a thrust bearing cap and that the caps were just numbered incorrectly from the manufacturer.
