Old 12-09-2012, 10:43 AM
J.C.you's Avatar
J.C.you J.C.you is offline
Has anyone else tried this McCarty/BES head bolt cooling mod? It does look much easier to do than running external coolant lines. I have serious doubts it’s actually going to work though.
Yes that is a head bolt you can see through the opening in the intake port.
Run it.......i would be more concerned about the log in the middle of the port rather than cutting thru a small amount at the head bolt.
Not to discredit...but why is the area around the head bolt darkened compared to the rest of the port wall that was hit with the common sand roll?
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
  #542
Old 12-09-2012, 11:26 AM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Discredit who? I’m not sure why it looks like that either. Below are additional shots of some of the other ports.
ID:	305600   Click image for larger version
ID:	305601   Click image for larger version
ID:	305602   Click image for larger version
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #543
Old 12-09-2012, 11:39 AM
T Syron's Avatar
T Syron T Syron is offline
Maybe you should post a few of those pictures on yellowbullet...guaranteed BES or someone who works for them or knows them follows the bullet.
I would like to their response on the main cap pictures.
Tom Syron
  #544
Old 12-09-2012, 12:58 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
Originally Posted by GTO Dan View Post
I really hope this all works out for you. You deserve a break, this gets worse everytime you post.
Are you certain that the engine wasn't delivered as is to BES and they just dynoed and tuned it?
Have you heard back from BES or are they not responding to you because Lynn was their client on this engine and not you? Did you pay BES directly or through Lynn? Did you work with them directly or through Lynn?
  #545
Old 12-09-2012, 01:11 PM
John Langer's Avatar
John Langer John Langer is offline
I have been running that exact same head bolt cooling mod since around 2003. If you sleve the bolt hole it would be more of a protrusion then the bolt itself. As far as the numbering of the main caps, I highly doubt that they remachined a thrust bearing cap and that the caps were just numbered incorrectly from the manufacturer.
  #546
Old 12-09-2012, 01:31 PM
RAIV-Z's Avatar
The head bolt cooling mod was only done to one of the V heads. Did you have this done to both of yours?
Seriously John, are you saying this should be a non-issue? Should the opening be cleaned up so the material around the opening is thick enough so it doesn’t flake off?
This is my first aftermarket block, are the main caps stamped by the MFG?
I agree, I doubt BES re-machined the thrust bearing cap.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #547
Old 12-09-2012, 01:40 PM
RAIV-Z's Avatar
Nothing back yet, I wouldn’t expect a response until at least Monday. BES was paid via Lynn. I talked to Tony a few times early on and then after the engine was delivered regarding some of issues with the heads and valve train. I worked mainly through Lynn.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #548
Old 12-09-2012, 02:22 PM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
Not a big fan of stamping delicate engine parts like connecting rods or main caps. If I stamp them, which I do sometimes, plan on resizing the housing bores. At a minimum, check therm before use. Stamping will distort them, especially aluminum rods. I much prefer using an engraver. Just another little trick I learned from the best, Joe Mondello and a few other "old timers". It's all about the details.
X2
I started engraving the last three digits of the block serial number on the caps just to make sure they don't get interchanged.
The newer IA-II caps are all drilled with two bolt bosses, I'll mount a fixture to assist in pulling the caps off.
I've seen a few cast caps crack because someone used the sledgehammer method or pulled up one side much more than the other.
Things happen when building custom race engine. IMO, it's how the company communicates and helps to resolve the issues that's most important.
Calvin Hill
Hill Performance
708-250-7420
  #549
Old 12-09-2012, 03:00 PM
Yes, it is a non issue. I have had bolts that look almost like your push rod tubes in the side of my port. If it is on one of the heads and not the other it would be due to core shift. Again, no big deal. I have even had this on the exhaust side. Those bolts will experience alot of heat.
  #550
Old 12-09-2012, 09:05 PM
Originally Posted by 65nss4spdGTO View Post
X2
Calvin Hill
Hill Performance
708-250-7420
I engrave "BE" on the #2 Cap. (Only need to mark one of them). The "E" points to the front of the engine.
You should know where the Rear Main Cap, the Thrust Main Cap, and the Front Main Cap go automatically. The only possible error would be mixing #2 and #3 and/or (putting them on backward. I have actually seen that happen).
Tom Vaught
  #551
Old 12-09-2012, 09:37 PM
Tom Vaught
I mark them to match the block serial number as I've had as many as four different builds going on using the same style block.
Calvin Hill
Hill Performance
708-250-7420
  #552
Old 12-11-2012, 06:55 PM
RAIV-Z's Avatar
I talked to a few people including Tony and Bob C. regarding the main caps. The general consensus is that although the hammer marks are ugly they will not weaken the main caps. We’re not sure how the marks or double stamps got there. Tony is also willing to work with me on some of the other issues.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #553
Old 12-11-2012, 06:59 PM
cgeise's Avatar
cgeise cgeise is offline
That does NOT answer who did that crap -
  #554
Old 12-21-2012, 10:58 PM
RAIV-Z's Avatar
Cage is out of the car for final welding.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #555
Old 12-22-2012, 07:44 PM
taff2's Avatar
taff2 taff2 is offline
Shouldn't you have a seat support tube under the driver,from the outer floor tube to the inner floor tube? Looks good though.
  #556
Old 12-23-2012, 08:22 AM
67'7F6'Bird's Avatar
Mccarty already put the bar under his seat.
  #557
Old 12-23-2012, 11:41 AM
GTO Dan's Avatar
LOL! Now that is funny, very cleaver.
Truly sorry to hear of RamIV-Z continuing issues and not trying to trivialize his situation ,but your comment really made me laugh.
  #558
Old 12-23-2012, 12:00 PM
Maybe he needed a support rod to go with the Titanium Plate I sent him a while back.
Tom Vaught
  #559
Old 12-23-2012, 01:35 PM
lemans411's Avatar
lemans411 lemans411 is offline
well everyone else seems to think this is ok and maybe they've had good luck with this but in my experience it has been an issue./
on a set of wenzler heads i had there was one stud that was open into the intake port. i ran it that way for a while and it was fine, but after time oil worked its way into the hole and when i would get on it it would suck that oil into the port and smoke like crazy. i took the head off and had a sleeve put in the hole and the smoking stopped. mine was a bigger opening than your pic shows but i thought it was worth mentioning
-Rob
67 LE MANS in pieces...
68 gto
84 grand prix twin turbo 496 pontiac 25.3 cage
  #560
Old 12-23-2012, 08:46 PM
warriors revenge warriors revenge is offline
Send a message via Yahoo to warriors revenge
many years ago, when Dan Whitmore would do a "race port" job on a set of RA IV heads, he would break thru the pushrod hole, and epoxy a bronze sleeve in there to seal the port up.... the same should be able to be done for a head bolt....
just sayin
