I use that same color for most of mine also.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
Ta_man, have you been running 1.65's on the intake and exhaust? Theres been talk on this site the with good flowing heads, 1.65 may be too much on the exhaust side especially with a split pattern cam(like OF) . Something about over scavenging? May possibility pick up with 1.5's on the exhaust?
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports, 3" pypes, Hooker 1 3/4" headers, hydraulic roller, 10" Continental, 3.42 gears 11.5 @117.5mph 3900lbs ![]() ([_|_] ##\|/##[_|_]) |
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 Last edited by ta man; 05-11-2017 at 01:54 PM. |
Dave said he's had excellent results so far. I only have 4 dyno pulls on mine but there was no sign of valve float.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 |
Some might be interested...
Exploring Rocker-arm Ratio and Cam-phase Tuning – Project Pure Poncho http://www.hotrod.com/articles/hppp-...-phase-tuning/ Brings up the subject of less rocker ratio on the exhaust side. Keep in mind here Pontiac factory iron heads are in use. The exhaust-to-intake flow ratio of aftermarket cylinder heads might be a all different ball game. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
Wonder if Dave would advocate using beehive springs?
What are specs on OF2?
Dave is not publishing full specs. On the surface, it is the OF with higher lift, and slightly more duration.
Sent from my XT1585 using Tapatalk
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight |
My ported round port E heads liked 1.8 on the intake and 1.65 HS (1.71 actual) on the exhaust the best.
Hi Skip, what happened when you tried more ratio on the exhaust?
Paul I did not see your question back then-I only bought enough to do the intakes as they are pricey. I did have the 1.65 HS on both intake and exhaust and it picked up with just the 1.8s on the intake.
good luck sounds like you are dooing great
1980 TA 455 th400 2.56 posi [email protected] http://www.dragtimes.com/Pontiac-Tra...lip-29967.html http://www.youtube.com/watch?v=6X5XJ9PR1Qw https://www.youtube.com/user/hal101/videos |
I think 10.78 at 125 and possibly better than that.
You should be close. I need to add more weight to keep my boat at 11.5, even in marginal air!
ta man, I noticed you are running a nice cast aluminum valley pan. Just in the process of freshening my 462 with some KRE heads, after seeing yours am thinking of getting one. Do you run a PVC with that valley pan or did you connect it somewhere else?
71 Goatman Hot Rods & Horsepower.......A diease for which there is no cure. 71 GTO, 463, SD 295 d-port heads, 10.75:1, RPM intake, 502hp/560tq @ the crank, 200r4, 10" Continental convertor, Bullet 234/244 cam, Cliff's Q-Jet, 3:42's w/Eaton True Trac, 5 Power Tours. New performance numbers coming
How are you allowed to run sub 11.50 w/o the required safety equipment?
1967 Firechicken, 499", Edl heads, 262/[email protected]" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. [email protected] mph with a 1.45 60'. Still WAY under the rollbar rule. |
Easy tech on testntune nights.There are usually quite a few newer cars especially the Mopars running in the 10's.I do have a SFI balancer,flexplate,proper lugs on the axles.I've been torn between putting a rollbar in this one or find another roller that is setup.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 Last edited by ta man; 08-02-2017 at 01:45 PM. |
Engine looks great, you are almost there!
Chris D 69 GTO Liberty Blue/dark blue T400, 9" w 3.50s, 3905lbs 461, 850 Holley, T2, KRE 310s, Comp HR 236/242D .572/.594L, RA manifolds, 11.53@114, 1.55/60 The spare: 467, 850 Holley, T2, Edelbrock Dport 310cfm w RA manifolds, Howard HFT 245/251D .561/.594L, 11.59@ 114, 1.57/ 60' |
Thanks take man I am going to pick one up, like the idea of not bending, looks great too!
