Old 12-06-2012, 11:00 PM
67'7F6'Bird's Avatar
The installation tool used is called the "McHackey."
  #522
Old 12-07-2012, 12:23 AM
Rob B's Avatar
Rob B Rob B is offline
Just curious, what tool do you guys generally use to seat the main caps?
Not a BFH!! Looks like someone used that specialty tool on those main caps!
What's up with 2 stamped over the 4 on the mains???
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
  #523
Old 12-07-2012, 03:32 AM
Jack Gifford's Avatar
Jack Gifford Jack Gifford is online now
formerly 'Pontiac Jack'
Omigosh...
  #524
Old 12-07-2012, 08:10 AM
mechanickeith's Avatar
The 4 is also stamped over the 2.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
  #525
Old 12-07-2012, 08:39 AM
mgarblik mgarblik is offline
Not a big fan of stamping delicate engine parts like connecting rods or main caps. If I stamp them, which I do sometimes, plan on resizing the housing bores. At a minimum, check therm before use. Stamping will distort them, especially aluminum rods. I much prefer using an engraver. Just another little trick I learned from the best, Joe Mondello and a few other "old timers". It's all about the details.
  #526
Old 12-07-2012, 09:44 AM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Angry The Ugly
Has anyone else tried this McCarty/BES head bolt cooling mod? It does look much easier to do than running external coolant lines. I have serious doubts it’s actually going to work though.
Yes that is a head bolt you can see through the opening in the intake port.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #527
Old 12-07-2012, 12:21 PM
R 70 Judge's Avatar
Seriously, WTF is the deal with this engine? It's one problem after another
James
1970 Trans Am
  #528
Old 12-07-2012, 01:19 PM
Rob B's Avatar
x2. I spent the time reading thru all the pages awhile back and that thing is scary!! From everything I've read and the photo's posted, none of this looks or sounds remotely like something BES would initially do in any of their builds, now what happens to it after it leaves their shop can be another story! They are local to me and I've never heard anything negative on the quality of their work and They've been around for a long time in this area. I know who I'd be pitchin a fit with on all of this.
Sad deal.
  #529
Old 12-07-2012, 01:24 PM
RAIV-Z's Avatar
Sad deal.
This engine was shipped directly from BES.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #530
Old 12-07-2012, 01:30 PM
Rob B's Avatar
Have you talked directly with them over this? I'm just stunned to believe that they are totally behind the build of your motor and some of the hack work pictured in your post.
  #531
Old 12-07-2012, 01:33 PM
cgeise's Avatar
cgeise cgeise is offline
This ******* deal is a hack job - unbelievable - I would contact BES and find out EXACTLY what there envolvement was - some one needs an asskicking over this deal
  #532
Old 12-07-2012, 02:04 PM
RAIV-Z's Avatar
I reached out to BES this morning via email.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #533
Old 12-07-2012, 06:53 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
I really hope this all works out for you. You deserve a break, this gets worse everytime you post.
Are you certain that the engine wasn't delivered as is to BES and they just dynoed and tuned it?
  #534
Old 12-07-2012, 07:11 PM
RAIV-Z's Avatar
Yes, I'm sure.
On a positive note, it can’t get much worse as there is not much left to take a part. Knock on wood…
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #535
Old 12-07-2012, 10:33 PM
jdw_poncho's Avatar
jdw_poncho jdw_poncho is offline
Can you just chorme plate them? I always heard making something shining makes it fast?
Sorry to see more of your engine parts was treated the same way. But the bare block I received had the same hammer marks on it. I purchased mine "unused" from someone on the board. Maybe they let each other use the same tool..... or a tool was using the wrong tool.
Hopefully a quick check says it ok?
  #536
Old 12-07-2012, 11:05 PM
Tom Vaught's Avatar
Boost Engineer
That was a BFH to make that kind of dent in the caps. Whatever happened to using BRASS tools to snug things in place?
Tom Vaught
  #537
Old 12-08-2012, 08:26 PM
taff2's Avatar
taff2 taff2 is offline
Looks like they let the apprentice teaboy build your engine,that is rough work.
  #538
Old 12-08-2012, 08:32 PM
Tom Vaught
Brass hammer is fine. I also use a plastic dead blow hammer with the lead shot inside. Works great. That main cap is fubar'd!!
Keith Collier
Tech advisor
POCI.org
  #539
Old 12-08-2012, 10:12 PM
pontsd pontsd is offline
Thumbs down Accountability
WOW,
Wt....f happened here !! This is worse than a nightmare on elm street .
I can not understand how this could have gone so bad and have BES name or involvement
This is looking like someone has no clue, but the Bigger problem is they did , WHOEVER was working on that engine did not give one **** about it and in the end has done great damage to their reputation and BES !!
Really sad , sorry man.
Please don't delete this, as this needs answers.
  #540
Old 12-09-2012, 10:31 AM
Tom Vaught's Avatar
Boost Engineer
X2
I try to treat each part very carefully and check every part several times. I also use an engraver to mark parts, if necessary. I try to work on only one assembly at a time which keeps the possibility of mixing parts remote.
I do not build an engine when I am tired or in a hurry.
Tom Vaught
