#541
I've had this issue in the past, to the point that the rotor button actually makes contact with the cap and knocks the rotor button out of phase. Before the rotor button was bumped, it had erratic timing and was impossible to set correctly. I don't believe timing here was rock steady with a distributor that looked that bad. |
#543
Don't think so, his guess of a bent oil pump shaft wasn't the issue. It was actually the distributor moving the shaft. My guess along with Dataway should have gotten the OP in the right area and the problem discovered.
Looks like we'll have to cut that sign in half and split between us
#544
I'll offer up my half of the sign to whomever deserves the other half. My shop has no wall space left
#545
.......Onward Thru The Fog!
#546
Not that I have any say, but if I had a vote I would recommend sending it to Paul, he more than deserves an award for his unwavering support through this challenge!
#547
Yep.
#548
I already have one, so I'll let you guys fight over it!
#549
Put the sign up for a charity auction with the proceeds going to Va68goat. If it's anything like BarrettJackson it should go for HUGE money and then the winner of the auction can donate it back and auction off again....OK maybe not....glad the problem was found before there was an explosion.
#550
You could just give it to me.....I knew exactly what the problem was but I didn't want to embarrass Paul or the other pretend experts, so I didn't post my opinion.
Karl
#551
Shoulda, woulda, coulda...
Paul deserves a big shout out for being a stand up guy, and Va68Goat deserves a reward for persistence. Now put the engine together, slap it in the car, and do a burn out. Congrats! |
#552
Thanks! I appreciate that. I can't wait to see that burnout video!
#553
I've been thinking about the windage tray thing. Now I question whether the rod bolts were actually hitting the windage tray once the engine was running. Even Hywaystar said he could not hear it hitting when turning the engine over. I shimmed the tray at the shop when I first built it. I shimmed it because it was obviously hitting the rod bolts when I just bolted the tray to the main caps. When it hit then, it would have left marks where it hit. That's why I shimmed it in the first place. After they shimmed it more, the noise was still there. But the witness marks where on the tray already because it was hitting when I first installed it. I think everyone just assumed because there were witness marks that it was still hitting, but those witness marks would not have gone away after I initially made them. I don't think it was ever hitting after the engine was running. The witness marks are so faint and minor, that I bet the shims I installed was enough to make it clear just fine. But at this point, that's all water under the bridge. Now I just need to get it back together so it can be enjoyed.
#554
Just to let you guys know...MSD stood by their product. They repaired the distributor at no charge and got it back to Paul already. I think thats awesome that they did that. I sent Paul a new distributor gear from Butlers. Hopefully I'll be enjoying this car soon!!!
#555
Guessing the OP is having too much fun finally getting to drive it to post on here.
Clay |
#556
Well, apparently there was a lot more damage to the motor than just the distributor bushing. I don't think this is the place to discuss what is going on but I don't think I'll be getting this motor back anytime soon.
#557
What kind of damage? The previous inspection above by Paul said everything was fine internally?
Paul, you found something after that? .
#558
I'll text you HWYSTR455. This is not a good situation here. I don't think I should post anything further until I find out how this is going to get resolved.
#559
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
#560
I'll call you grivera. After the news I got yesterday, I've been just trying to get my head straight.
| Closed Thread |
