#41
I recieved my US Bandits yesterday. Very nice they are.....made in US they are not. Made in China right on the wheel.
#42
China Mag Bandit? haha jk I am wondering if the tooling was made in the US, but then shipped to China where they are mass produced
www.fquick.com/Captainofiron 68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4 97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil 14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires |
#43
It actually is cast into the wheel on the backside. "Designed in the US" "Made in China" Also these are advertised as 0 offset, the boxes say 8mm offset. Not sure if it will make any difference?
#44
It would also be great to set a PMD cap on the center of the wheel and see how it fits. Thanks!
68 Firebird, trying a q-jet now. 434/10.5:1/997's/240-242 HFT/4L80E/2800 Yank/3.42's/ Vintage Air/ 13.0 @105 mph 70 Lemans, 350/350, A/C, mostly stock 14 Ram CC, 5.7 Hemi, 8-speed, 3.92 lsd 97 Trans Am, HPP Aug 2012 http://www.highperformancepontiac.co...tiac_trans_am/ ***Sold*** |
The Following User Says Thank You to quicksilver97ta For This Useful Post: | ||
#45
+1 please
#46
also don't forget that backspace and offset are 2 diff things http://www.youtube.com/watch?v=2K1lUlv9ZOA
___________________________________________ the more im around people, the more i like my dogs |
The Following User Says Thank You to hada76 For This Useful Post: | ||
#47
I just read that backspace and offset or 2 different ways of measuring the same thing. The 17x8 wheels are 0mm offset or 4.25" backspacing, the 17x9 wheels are +8mm offset or 5.25" backspace. The place I bought them from said he messed up the listing, he was selling a staggered set 17x8 and 17x9 and listed them all as 0 offset.
#48
I like the PMD caps too- after seeing them on the Bandits they look like they belong on them. It's not a huge priority to me, but down the road I will get some. I'll check the big brake clearances once my wheels come.
Geno |
The Following User Says Thank You to 72blackbird For This Useful Post: | ||
#49
Did you get a chance to weigh them? Thx
1972 LeMans 461 stroker 10.3:1 Edelbrock D ports Scorpion 1.5 rockers Comp Cams "Stump Puller" roller Holley Ultra Street Avenger 770 Ram Air III exhaust manifolds 2.5" pipes Dynomax VT w/crossover Edelbrock Performer RPM TH350 2.78:1 10 bolt |
#50
from what I remember for a 1st gen Firebird you need a 5.5 back space to fit the 17x9s on the back and a 4.5 on the front to get 17x8 I wonder if they have those backspacings
#51
Lotsa room back there!
The wheel holes are also .625" diameter, making fitment on aftermarket hubs using 1/2-20" studs a bolt-on deal. Geno |
#52
It is possible to retrofit Pontiac caps. I am going to end to go with a new set of the red lucite centers. Here's the '66 GTO with 18 X 8's and 18 X 9's. For comparison's sake, here is a '67 LeMans with the 17 X 9 YO wheels. I prefer the Bandits myself. As someone else aid, the YO wheels look good, but they appear too sharp or squared off looking to me. The Bandit seems to flow better and I prefer the bigger openings in them.
'67 GTO 400 HO - Ram Air - 4 speed - 3.55 Safe T Track, A/C, PS, red fender liners '78 Lemans - Drag car project |
The Following User Says Thank You to 67GTO4SPEED For This Useful Post: | ||
#53
#54
#55
I agree- both look good to me, but being a Pro-Tourer made the choice real easy. The Bandit is lighter, cools and shows off big brakes better- plus Year One doesn't make a Rally II style in 18" sizes.
I would also be curious to know how much the YO 17" Rally II weighs in comparison to the 17" Bandit. The 18 x 9 cast 1-piece Bandit weighs about 30 lbs.- I would imagine the 17" would weigh a little less. Geno |
#56
The Bandits are pretty deep in the rear, but I can't see how the guy with that blue LeMans is getting away with running 9's on the front. My 8's with the 245/60's are very close to rubbing, and I am still is going to lower the front of my car more to match the rear.
At the end of the day, they both look good, I just like the Bandits a little better. I'm just glad with have options with these Pontiacs. I built a '69 Firebird in the early 90's and parts were hard to get to Pontiacs then. It's amazing how much more aftermarket there is now compared to 25 years ago for these things.
#57
I did a little homework, it's not verified, but what I came up with so far is the C5/C6 brake setup has a caliper offset of .790 - .812, so not sure these will clear. I have ATS AFX spindles, and the Touring Classics brake setup, which may be a hybrid setup, that too is not clear, Touring Classics is out of business, so templates are not available.
I guess I'm stuck having to measure, unless I can find someone with one of the templates. Maybe I will post over at pro-tour, see if someone over there can come up with something. .
The Following User Says Thank You to HWYSTR455 For This Useful Post: | ||
#58
I have the hybrid setup, it looks like the caliper measurement is .711, and luckily, I found and archive site that houses old websites (https://archive.org/) , and was able to download a template.
Any chance I can get someone to check the wheels with the template? It would provide others with exact measurements for future reference, sure would help! .
#59
The US mag website has 'made in USA' on the forged 2/3 piece version of the wheel, and this line is not present on the cast 1 piece version of the wheel.
Good to see options on wheels like these. http://www.mhtwheels.com/mht-luxury-...el.cfm?id=2782 Mike
No Pontiacs in the garage right now..... |
The Following User Says Thank You to mbwicz1 For This Useful Post: | ||
#60
Made in China.....
