Old 07-17-2004, 05:38 AM
soupman soupman is offline
Ron-
I was thinking of installing these on the 72 T/A I have all stock. I will bring this car to the strip with stock exhaust and see what it runs. I will then run the new tri-y to see if any difference. Will keep in touch and post the results.
Chris
  #42
Old 07-17-2004, 07:23 AM
lumarkhood lumarkhood is offline
I am in for a set of O ports with 2 1/2"!
Mark
Trans Am's, Formula's, Mustang, GN...
  #43
Old 07-17-2004, 08:44 AM
TUNNEL PORT's Avatar
TUNNEL PORT TUNNEL PORT is offline
Thanks soupman,
That will go good with the Dyno info that Byron (screen name bmpmdf) who is going to be in the Eng Masters contest & will have diff motor on the dyno in about a week or so. Its projected to have around 400-450Hp. So I'll test a 4-tube, a O-port Try-y & R/A manifold & post the results.
Old 07-18-2004, 08:46 PM
Heres a link to the pics & prices
http://www.bbgraphics1.com/tri-y/
Old 07-19-2004, 03:15 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
OK Ron:
I've been watching this thread since it started, and I'm convinced!
I'll be sending you an e-mail. Please count me in for a set of thermal coated round ports with the 2.5" collector.
Thanks!
Regards,
"455HO" Lloyd
  #46
Old 07-19-2004, 03:24 PM
briann briann is offline
I am wondering if the 2.5" collector is the way to go since its a tri y design and having a 3" collector might not help out with flow all that much since its not a 4 tube design. Its only the 2 larger tubes entering into that area for the collector and not 4. One might be able to just run a 3" pipe off of the 2.5" collector to help with the ground clearance issuse only with the 3" collector.
  #47
Old 07-19-2004, 07:59 PM
Brian,
I confirmed with the header co that the 2 1/2" would more likely have more scavenging effect to it than the 3" would. Because its a smaller step up in size. So you may not have as much response at lower RPMs with the 3". I am going with the 2 1/2" myself not only for the added ground clearance but for the better response. & since I wont have both a 3" & 2 1/2" at the same time for the Dyno test, I wont be able to test that idea for a while.
Ron
Old 07-19-2004, 08:09 PM
I have 3" pipe on now in anticipation for the supercharger setup, but I know its hurting me low end right now before I get to that point in project. I think the 2.5" collector size will be just fine as long as everything behind it is free flowing.
Old 07-19-2004, 08:28 PM
I run a set of the original round-port HO Tri-Y headers on a '64 GTO bracket car. The car has a full 3" exhaust hooked up to the 2-1/2" collector, makes for great mid-range and pretty decent top-end power.
The engine is a fairly mild 455 with 8.6:1 compression, the '71 HO heads have some bowl work and very minor port clean-up. Runs the HC-03 cam (244/252,.550/.554" w/1.65s) and a stock Torker II/650 DP Holley.
Best ET (3550# race weight):[email protected]
Even with the small carb and 2-1/2" collector it wants to rev to 6K, but I shift it at 5200. You can make very good power with Tri-Y headers.
These headers cost $350 OVER 10 YEARS AGO.
The new version being offered by TUNNEL PORT is a must-have for 2nd-gen bird owners and they are priced right. Don't blow what very well might be your only chance to get your hands on a great set of headers.
  #50
Old 07-19-2004, 08:37 PM
Well my problem is I have ported D ports on now id like the tri-y's for, but will most likely be throwing the SD heads back on this winter so I have to decide on which version to buy as I cant quite afford D and O ports together unless he has a buy 1 get 1 free offer. LOL
  #51
Old 07-19-2004, 10:50 PM
Lloyd-tx,
You got mail.
Thanks b-man, I tried to get them out as affordable as possible.
Briann,
I am running a 2 for one offer. If you pay twice as much for the first set, then I'll trough in the 2nd one of same or less value for no extra charge
Old 07-20-2004, 04:58 AM
Larry Navarro's Avatar
B-man is Right!!!
I paid over $350 for my set of Tri-Y's 10 yrs ago too!
Get'em now.....no whiners afterwards!
  #53
Old 07-21-2004, 06:32 PM
robscar's Avatar
robscar robscar is offline
i wish you well on this endeavor. i do not have a vehicle that this application fits, so i will wait until (hopefully) you do a set for the early a bodies. much success to you.
  #54
Old 07-21-2004, 11:10 PM
robscar,
Thanks, "IF" everything goes well it will be the end of next month before I can get setup for A-bodys. I plan to do my R/A V headers around that same time.
Ron
Old 07-22-2004, 08:47 AM
OK its Thur. I have someone that is going to front me the amount that will be in the Pay Pal account so I can accept pay pal until Fri afternoon without having a 3-4 day wait to transfer funds to the header co. Also this allows me to accept deposit for this order of 1/2 down at time of order & 1/2 at ship date for those who cant get the full amount in on time. That will give 2 weeks for the balance incase they need another pay check.
Old 07-27-2004, 04:32 PM
I had to purchase a few sets my self to make up the remainder of the minimum order that was placed on Mon. So for a few of you guys, its not to late.
Ron
Old 07-27-2004, 05:52 PM
Lloyd-TX's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by TUNNEL PORT:
Ron <HR></BLOCKQUOTE>
Come on, guys - lets support this venture and buy the extra sets from Ron. Just can't go wrong on the engineering, quality and the price!
Regards,
"455HO" Lloyd
  #58
Old 07-28-2004, 12:46 AM
78 GHOST 78 GHOST is offline
Umm, OK Lloyd.. I'm in.
Sounds like a very cool project. Now to decide which ones to get for my next big project? O or D??
Ron, my email is: [email protected] or [email protected]
Drop me a phone number and we'll work out at least 1 more order for ya.
____________________________________
"I work in high speed aluminum tubing."
  #59
Old 07-28-2004, 11:02 AM
Lloyd-TX's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Matt D. 78 GHOST:
Drop me a phone number and we'll work out at least 1 more order for ya. <HR></BLOCKQUOTE>
Honorable Matt - but remember these are F body headers!
Regards,
"455HO" Lloyd
  #60
Old 07-28-2004, 11:57 AM
Lloyd, I thought you knew I had twins..
Gotta plan that next project.. 650HP all motor, with A/C and Power Brakes.. yum!
Spoke with Ron this A.M. and the money is already on the way for some 2.5" coated D-Ports.
